11-12-2019 02:26 AM
I am in need of the 16 console port terminal router for small office.
Please suggest the model number.
11-12-2019 03:19 AM
I have used 4321s with the NIM-16A or NIM-24A, but based on the price of these, it is becoming increasingly difficult to justify them over purchasing a dedicated console server from another supplier.
Hope this helps,
Dave
11-12-2019 03:47 AM
I think You can bay another 2511 on ebay :-)
Other way - use small PC and PCI-X card with 16 RS-232 but it have high cost.
11-13-2019 10:33 AM
get a 2811 or 2911 with a NM-16A or NM-32A with the octopus cables.
Cheap solution should cost you around $100-$150 on ebay
