RME 3.3 and Configuration Management.
andrea.meconi
Level 2
Level 2
Hello!
I have a problem with Configuration Management from RME 3.3 on WinNT.
When I try to Update Archive and select a device from list the operation fails!
More info...
Probable Cause: failed to initiate telnet session, cannot resolve host PIPPO!!!
But I don't have DNS, only host file is populated!
If I try telnet from CW2000 server and it is ok!
Why this?
Thanks!
rmushtaq
Level 8
Level 8
Is your device credentials correct?. Also, have you added the device in RME with name?. Is so, delete and re-add it back with it's ip address and then retry.
Yes, device credentials are correct.
I have added the device in RME with name and DIServer cannot resolve host name! With it's IP address I can import device correctly.
Thanks.
Andrea.
