Router 827 memory SegV problem
merrikhipm
hello
I can't seem to save any configuration I make to the my router for some reason.... can anybody help me.
the error reacts when I type 'write'.
=== Flushing messages (00:01:00 UTC Mon Mar 1 1993) ===
Queued messages:
Data TLB Miss Exception (0x1200)!
CPU Register Context:
VEC = 1200 PC = 8066F100 MSR = 9032 CR = 53000000
LR = 801673A4 CTR = 80109BB
R0 = 0 R1 = 80CD63E8 R2 = 80980000 R3 = 80B1C074
R4 = 7F5A76B0 R5 = 0 R6 = 0 R7 = 0
R8 = 5 R9 = 1 R10 = 80B1C074 R11 = 0
R12 = 93000000 R13 = FFF31FC8 R14 = 0 R15 = 0
R16 = 0 R17 = 0 R18 = FFFFFFFF R19 = 80980000
R20 = 6 R21 = 809C3F64 R22 = 0 R23 = 0
R24 = 0 R25 = 80A369B6 R26 = 0 R27 = 0
R28 = 80A35628 R29 = 80990000 R30 = 80A58974 R31 = 80A58988
Stack trace:
PC = 8066F100, SP = 80CD63E8
Frame 00: SP = 80CD63E8 RA = 80167980
Frame 01: SP = 80CD6410 RA = 8011F77C
Frame 02: SP = 80CD6440 RA = 8006B2A0
Frame 03: SP = 80CD6460 RA = 80096C18
Frame 04: SP = 80CD6480 RA = 8008B720
Frame 05: SP = 80CD6490 RA = 80099A30
Frame 06: SP = 80CD64E0 RA = 8011A09C
Šrame 07: SP = 80CD6558 RA = 0
*** System received a SegV exception ***
signal= 0xb, code= 0x1200, context= 0x809dabf0
PC = 0x8066f100, Vector = 0x1200, SP = 0x80cd63e8
System Bootstrap, Version 12.1(1r)XB1, RELEASE SOFTWARE (fc1)
Copyright (c) 2000 by cisco Systems, Inc.
C827 platform with 16384 Kbytes of main memory
Prashanth Krishnappa
It appears you are running into the following bug
http://www.cisco.com/cgi-bin/bugtool/onebug.pl?bugid=CSCee41831
This bug is still being worked on. As a workaround, back up your config, issue "wr erase" command on router and reload it afterwards.
The router should come up with no config, apply the config which you saved and you should be able to issue a wr mem.
Hope this helps
Thank you for your help prkrishn
However I've already tried that and im in the midst of doing it again. I have a backup of the IOS from a long time ago that I keep uploading through xmodem and it still seems to make the same error.
Anythoughts as to how I can get another IOS without being a registered member?
thanks again for your help
can this problem also be linked with the ROMMON?
so if I do indeed get another IOS the same problem will continue.
-The Stack-
IOS (tm) C820 Software (C820-Y6-M), Version 12.1(5)YB3, EARLY DEPLOYMENT RELEASE
SOFTWARE (fc1)
TAC:Home:SW:IOS:Specials for info
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Thu 10-May-01 11:31 by ealyons
% Type "show ?" for a list of subcommands
Router#show stack
Minimum process stacks:
Free/Size Name
5700/6000 Autoinstall
10404/12000 Setup
11524/12000 BootP Resolver
4088/6000 DNS Snoop
9804/12000 Init
Interrupt level stacks:
Level Called Unused/Size Name
1 0 9000/9000 ADSL Dying Gasp Interrupt
4 91032 8524/9000 MPC860 CPM INTERRUPT
5 7157 8528/9000 ADSL Ctrl Interrupt
7 83570 8900/9000 TIMER INTERRUPT
System was restarted by error - a SegV exception, PC 0x8066F100 at 18:27:05 UTC
Tue Jul 6 2004
C820 Software (C820-Y6-M), Version 12.1(5)YB3, EARLY DEPLOYMENT RELEASE SOFTWARE
(fc1)
Compiled Thu 10-May-01 11:31 by ealyon (current version)
Image text-base: 0x80013170, data-base: 0x80672254
Stack trace from system failure:
FP: 0x80CD7EE8, RA: 0x8016735C
FP: 0x80CD7F10, RA: 0x80167980
FP: 0x80CD7F40, RA: 0x8011F77C
FP: 0x80CD7F60, RA: 0x8006B2A0
FP: 0x80CD7F80, RA: 0x80096C18
FP: 0x80CD7F90, RA: 0x8008B720
FP: 0x80CD7FE0, RA: 0x80099A30
FP: 0x80CD8058, RA: 0x8011A09C
******* Information of Last System Crash **********
and the debug from nvram -->
=== Flushing messages (00:06:49 UTC Mon Mar 1 1993) ===
Queued messages:
00:06:49: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging out
put.
00:06:48: %NVRAM: nv_check_getptr()- nv_exec_ipcrc() fails, nv->magic = nv->text
size = 0
00:06:48: NVRAM: nv->magic != NVMAGIC, invalid nvram.
00:06:48: NVRAM: invalid nvram, but return(1).
00:06:49: %NVRAM: nv_check_getptr()- nv_exec_ipcrc() fails, nv->magic = nv->text
size = 0
00:06:49: NVRAM: nv->magic != NVMAGIC, invalid nvram.
00:06:49: NVRAM: invalid nvram, but return(1).
