07-02-2003 04:19 AM - edited 03-02-2019 08:34 AM
Hello there,
I have router 7204, almost every day at no specific time, all router interfaces go down for a few seconds and then they come back up again. here is the content of the router log. Can someone point me to what might be going on.
Thanks.
00:00:11: %LINK-3-UPDOWN: Interface FastEthernet0/0, changed state to up
00:00:11: %LINK-3-UPDOWN: Interface Serial1/0, changed state to down
00:00:12: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0, changed state to up
00:00:12: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/0, changed state to down
00:00:12: %CONTROLLER-5-UPDOWN: Controller T1 2/0, changed state to up
00:00:12: %SYS-5-CONFIG_I: Configured from memory by console
00:00:12: %SYS-5-RESTART: System restarted --
IOS (tm) 7200 Software (C7200-JS-M), Version 12.0(7)T, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-1999 by cisco Systems, Inc.
Compiled Tue 07-Dec-99 16:53 by phanguye
00:00:13: %LINK-3-UPDOWN: Interface Serial2/0:0, changed state to up
00:00:13: %LINK-3-UPDOWN: Interface Serial2/1:0, changed state to down
00:00:14: %LINK-3-UPDOWN: Interface Serial1/0, changed state to up
00:00:14: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial2/0:0, changed state to up
00:00:14: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial2/1:0, changed state to down
00:00:15: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/0, changed state to up
00:00:24: %CONTROLLER-5-UPDOWN: Controller T1 2/1, changed state to up
00:00:26: %LINK-3-UPDOWN: Interface Serial2/1:0, changed state to up
00:00:27: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial2/1:0, changed state to up
07-02-2003 04:27 AM
Hi Sam --
Q. Is this a Frame-Relay Network?
Q. Have you spoken to your service prvider and if so, what have they said?
Thanks -
07-02-2003 05:51 AM
No, this is a point to point T1/T3 lines.
The service provider tells us that there is no line errors. It shows that in the sh interface serial command that there is no transitional errors.
Thanks.
07-02-2003 04:33 AM
your router is either crashing or it is losing power , look at a sh ver this will tell you if it is power or a crash , if it is the same time each day chances are the router is plugged in to something that is on a timer .
07-02-2003 05:58 AM
The uptime on the router is 2 hours, I think you're right as to why the router keeps crashing everyonce in a while. Could it be the power supply on the router or could it be a UPS issue.
Thanks for your help.
07-02-2003 06:02 AM
A 7200 would be complaining about a bad power supply , My guess is that the power strip is on some kind of timer that resets at the same time each night , the router is resetting at the same time each night .
07-02-2003 06:27 AM
No, the router resets at different times, sometimes once a day, once every two days or once every weeks. I wonder if there is an existing issue the current verion of the IOS.
IOS (tm) 7200 Software (C7200-JS-M), Version 12.0(7)T, RELEASE SOFTWARE (fc2) .
I want to check the cisco website and find out if there is a known issuses. I'll probably need to upgrade the IOS before taking any further actions.
Thanks.
07-02-2003 06:35 AM
We have run 12.0(7) T on many routers and this code is not very stable.
If you are hitting a bug it will tell you in a sh ver , it will sh last restart via software forced crash or something like that ,
paste in a sh ver
07-02-2003 11:57 AM
Here is the output of sh ver.
Image text-base: 0x60008900, data-base: 0x618CC000
ROM: System Bootstrap, Version 12.2(1r) [dchih 1r], RELEASE SOFTWARE (
LP-RTR uptime is 8 hours, 36 minutes
System returned to ROM by bus error at PC 0x604BFBBC, address 0xC at 1
C Wed Jul 2 2003
System restarted at 11:16:59 UTC Wed Jul 2 2003
System image file is "slot0:c7200-js-mz.120-7.T.bin"
cisco 7204VXR (NPE300) processor with 122880K/40960K bytes of memory.
R7000 CPU at 262Mhz, Implementation 39, Rev 2.1, 256KB L2, 2048KB L3 C
4 slot VXR midplane, Version 2.0
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
Primary Rate ISDN software, Version 1.1.
1 FastEthernet/IEEE 802.3 interface(s)
3 Serial network interface(s)
8 Channelized T1/PRI port(s)
125K bytes of non-volatile configuration memory.
20480K bytes of Flash PCMCIA card at slot 0 (Sector size 128K).
4096K bytes of Flash internal SIMM (Sector size 256K).
Configuration register is 0x102
Thank you very much !
07-02-2003 01:14 PM
the line
is telling you that this box crashed .
this is more than likely hardware . Open a Tac case ,
07-03-2003 09:47 AM
Thank you very much !!!!
