Routering problem (Beginner)
a_jam_sandwich
I’m yet again stuck on setting up our routers.
We have a router in Scotland configured on a 11.x.x.x network and a router 10.x.x.x in Rugeley these two devices works fine and traffic between is working fine.
Scotland f0/0 -> 11.0.0.250
Rugeley f0/0 -> 10.0.0.250
At Rugeley we also have another router to a lease line used to connect to the internet this router is 10.0.0.253
Traffic for the internet in Scotland/Rugeley goes through a proxy located in Rugeley this works fine.
The problem now is the proxy is only for internet traffic and a PC in Scotland 11.0.1.50 needs to contact a server 81.123.x.x in the outside world using the Lease Line Router 10.0.0.253 this is where I am stuck I have no idea how to do this.
The routers in Scotland and Rugeley are both using RIP2.
You help is greatly appreciated
Andy
8 Replies 8
sachin
You can enable NATing for 11.X.x.x network on internet router.
nope the router is not under our control :(
Is 11.X.x.x network is valid pool ? Have you got this pool from ISP ? Have your ISP done routing for the 11.x.x.x network pointing to your internet router ? If not , then you have to do NATing on router, there is no other way.
Hello Andy,
you could either configure a static host route on the router where the PC with IP address 11.0.1.50 is connected to:
ip route 81.123.X.X 255.255.255.255 10.0.0.253
or use a route map and redirect all traffic for that destination to your leased line router:
route-map LL_ROUTER permit 10
match ip address 101
set ip address 10.0.0.253
or
set ip next-hop 10.0.0.253
Interface FastEthernet0/0
ip policy route-map LL_ROUTER
access-list 101 permit ip any host 81.123.X.X
In the second example, your interface FastEthernet0/0 would be the interface where your host 11.0.1.50 is connected to. I do not know how your two routers are connected, but both the static route and the route map are configured on the router directly connected to the host, pointing to the leased line router.
HTH,
GP
Thank very much for your reply gpauwen. I have added the ip route into the scotland router the 11.x.x.x network. now when tracing the route it gets to the 192.168.1.2 (Rugeley Serial WIC) then I get destination host unreachable.
============ SCOTLAND CONFIG ============
hostname scotland
boot-start-marker
boot-end-marker
enable secret xxxx.
enable password xxx
no aaa new-model
ip subnet-zero
no ip domain lookup
no ftp-server write-enable
description connected to Scotland LAN
ip address 11.0.0.250 255.0.0.0
duplex auto
speed auto
interface Serial0/0
description connected to rugeley
ip address 192.168.1.3 255.255.255.0
encapsulation ppp
router rip
version 2
network 11.0.0.0
network 192.168.1.0
no auto-summary
ip classless
ip route 81.123.154.122 255.255.255.255 10.0.0.250
no ip http server
snmp-server community public RO
snmp-server enable traps tty
line con 0
exec-timeout 0 0
password xxx
login
line aux 0
password xxx
login
line vty 0 4
password xxx
login
end
Andy
Hello Andy,
I am not 100% clear on your physical setup, it seems to me that you need another static route on the Wigley router. Can you make a little schematic drawing, something like:
Router Scotland --> Router Wigeley etc.
GP
I do belive your right ive added a static route on the rugeley router and it no timesout which I think might be down to the gateway only allowing stuff on the 10.x.x.x network
Traffic flow
Request to 81.123.154.122
PC on 11.x.x.x network -> Scotland(ROUTER) -> Rugeley(ROUTER) -> 10.0.0.253(GATEWAY)
At present I have both the rugeley and scotland routers with static routes
IP ROUTE 81.123.154.122 255.255.255.255 10.0.0.253
And now I get a timeout instead of destination host unreachable from the rugeley serial card so I think that the NTL gateway(10.0.0.253) needs to allow traffic from the 11.x.x.x network.
What do you think
Andy
