Routing between two subnet
Yangjp715
Level 2
Level 2
Hi all,
I need to build an isolated network for a CUCM migration. The CUCM ip address and gateway is in 192.168.0.0/24, but the IP of the NTP server is 10.0.0.5/24. the following is my lab connection:
ESXi host (VMs in 192.168.0.0/24)-->SW2950(all interfaces are in VLAN1, default-gateway is 10.0.0.5)-->Cisco 2821 G0/0(Primary ip 192.168.0.1/24, the secondary IP 10.0.0.5/24). Is there any way that the NTP server 10.0.0.5 can be reached from VMs in 192.168.0.0/24?
Thanks in advance,
Eric
Eric
10 Replies 10
chrihussey
As long as the proper default gateways are defined for each subnet there should be connectivity. Is this not the case?
I connected my laptop to the 2950 in VLAN 1 and using IP 102.168.0.x to ping 10.0.0.5. It was not reachable, but 192.168.0.1 was pingable since they are in the same VLAN.
Can you post the config of the router, or at the very least the interface that connects to the switch?
Current configuration : 1307 bytes
! Last configuration change at 22:51:56 UTC Sun Jul 15 2018
! NVRAM config last updated at 22:51:58 UTC Sun Jul 15 2018
version 15.1
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ipv6 cef
voice-card 0
license udi pid CISCO2821 sn FHK1306F3D9
redundancy
interface GigabitEthernet0/0
 ip address 10.192.1.5 255.255.255.0 secondary
 ip address 10.192.143.1 255.255.255.0
 duplex auto
 speed auto
interface GigabitEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 10.192.1.0 255.255.255.0 GigabitEthernet0/0
ip route 10.192.143.0 255.255.255.0 GigabitEthernet0/0
nls resp-timeout 1
cpd cr-id 1
control-plane
mgcp profile default
gatekeeper
 shutdown
line con 0
line aux 0
line vty 0 4
 login
 transport input all
scheduler allocate 20000 1000
ntp source GigabitEthernet0/0
ntp master 4
end
Switch:
Current configuration : 1467 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch
ip subnet-zero
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
interface FastEthernet0/1
 no ip address
interface FastEthernet0/2
 no ip address
interface FastEthernet0/3
 no ip address
interface FastEthernet0/4
 no ip address
interface FastEthernet0/5
 no ip address
interface FastEthernet0/6
 no ip address
interface FastEthernet0/7
 no ip address
interface FastEthernet0/8
 no ip address
interface FastEthernet0/9
 no ip address
interface FastEthernet0/10
 no ip address
interface FastEthernet0/11
 no ip address
interface FastEthernet0/12
 no ip address
interface FastEthernet0/13
 no ip address
interface FastEthernet0/14
 no ip address
interface FastEthernet0/15
 no ip address
interface FastEthernet0/16
 no ip address
interface FastEthernet0/17
 no ip address
interface FastEthernet0/18
 no ip address
interface FastEthernet0/19
 no ip address
interface FastEthernet0/20
 no ip address
interface FastEthernet0/21
 no ip address
interface FastEthernet0/22
 no ip address
interface FastEthernet0/23
 no ip address
interface FastEthernet0/24
 no ip address
interface Vlan1
 ip address 10.192.1.4 255.255.255.0
 no ip route-cache
ip default-gateway 10.192.1.5
ip http server
line con 0
line vty 5 15
end
Am I missing something? I don't see an interface with 192.168.0.x as primary IP and 10.0.0.x as secondary IP?
Please clarify.
Sorry for misunderstanding. Actually all VMs are in the subnet 10.192.143.0/24, and the NTP server is 10.192.1.5 in production. I just used 192.168.0.0/24 and 10.0.0.0/24 for example.
OK....so these static routes are not necessary so remove them:
Then, you could try adding "no ip redirects" to the G0/0 interface on the router.
Finally, just verifying that the default gateways for the devices are the respective IPs of the two subnets on the G0/0 interface. So if you are on the 10.192.1.x network the gateway is 10.192.1.5  and if you are on the 10.192.143.x, it's 10.192.143.1 Correct?
Yes, it is correct.
Do i need to replace the 2950 by using a layer 3 switch and configure a default route on it, such as "ip route 0.0.0.0 0.0.0.0 10.192.1.5".
Is there anybody who have ideas for building an isolated network environment in Lab environment? Thanks.
