routing help
gcumarasamy
I have a 2610 with 2 ethernet interfaces and IOS 12.2(16). The ip addresses for those interfaces are 172.16.0.90/16 and 172.25.0.1/16.
I can ping all hosts on 172.16.0.0 subnet from the router using the 172.25.0.1 interface as source. But when I try to ping a host in 172.16.0.0/16 subnet from a host (172.25.5.1/16) it doesn't respond.
here is my router config :
IOSFW1#sh config
Using 904 out of 29688 bytes
version 12.2
service config
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname IOSFW1
logging queue-limit 100
enable secret xxxxxxx
enable password xxxxxx
ip subnet-zero
ip audit notify log
ip audit po max-events 100
call rsvp-sync
interface Ethernet0/0
bandwidth 100000
ip address 172.16.0.90 255.255.0.0
full-duplex
no mop enabled
interface Serial0/0
no ip address
no ip mroute-cache
shutdown
no fair-queue
interface Ethernet1/0
bandwidth 100000
ip address 172.25.0.1 255.255.0.0
full-duplex
ip classless
ip route 172.17.0.0 255.255.0.0 172.16.0.5
ip route 172.18.0.0 255.255.0.0 172.16.0.5
ip route 172.19.0.0 255.255.0.0 172.16.0.5
ip http server
dial-peer cor custom
line con 0
line aux 0
line vty 0 4
password xxxxx
login
end
Thanks for youe help in advance
thisisshanky
Level 11
Level 11
Did you check whether you are able to ping the host (172.25.5.1/16) from the router. Also check if the host is set with the right default gateway (172.25.0.1/16.)
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
Thanks for your help and my appologies.....typo on the gateway....typed in 172.25.1.0 instead of 172.25.0.1
Thanks again
The typo error doesnt realy matter, but, you should check the default gateway setting son the hosts on 172.25.0.0/16 network. Also ping from the host to the router and see if you can reach it.
Sankar Nair
