03-03-2004 04:20 AM - edited 03-02-2019 01:59 PM
I want to create multiples Vlans with this switch.My 6509 will be the core. My problem is how can I configure the interfaces to routing. When I start session 15 in enable mode I only get Vlan 1 when I use the show interface command. The must complicated part is that I can't get a physical interface an sub-interface to assigne my Ip address and mask. I need to know the commands I can use to fix this problem. How to configure VTP between router and switch?
Wich command can I use to configure inter-Vlans routing?
This is my output when using show modules command and some more specificacions.
Mod Slot Ports Module-Type Model Sub Status
1 1 2 1000BaseX Supervisor WS-X6K-SUP1A-2GE yes ok
15 1 1 Multilayer Switch Feature WS-F6K-MSFC2 no ok
2 2 2 1000BaseX Supervisor WS-X6K-SUP1A-2GE yes standby
16 2 1 Multilayer Switch Feature WS-F6K-MSFC2 no ok
3 3 48 10/100BaseTX Ethernet WS-X6348-RJ-45 no ok
4 4 48 10/100BaseTX Ethernet WS-X6348-RJ-45 no ok
5 5 48 10/100BaseTX Ethernet WS-X6348-RJ-45 no ok
6 6 16 1000BaseSX Ethernet WS-X6416-GE-MT no ok
7 7 16 1000BaseSX Ethernet WS-X6416-GE-MT no ok
8 8 8 1000BaseX Ethernet WS-X6408A-GBIC no ok
9 9 16 1000BaseX Ethernet WS-X6416-GBIC no ok
WS-C6509 Software, Version NmpSW: 5.5(1)
Copyright (c) 1995-2000 by Cisco Systems
NMP S/W compiled on Jun 8 2000, 21:09:45
System Bootstrap Version: 5.3(1)
Hardware Version: 2.0 Model: WS-C6509 Serial #: SCA043801E1
Mod Port Model Serial # Versions
1 2 WS-X6K-SUP1A-2GE SAD05040EBR Hw : 7.0
Fw : 5.3(1)
Fw1: 5.4(2)
Sw : 5.5(1)
Sw1: 5.5(1)
L3 Switching Engine SAD0504082D Hw : 1.1
2 2 WS-X6K-SUP1A-2GE SAD05030CD9 Hw : 7.0
Fw : 5.3(1)
Fw1: 5.4(2)
Sw : 5.5(1)
Sw1: 5.5(1)
L3 Switching Engine SAD05030BEJ Hw : 1.1
3 48 WS-X6348-RJ-45 SAL045047A6 Hw : 1.4
Fw : 5.4(2)
Sw : 5.5(1)
4 48 WS-X6348-RJ-45 SAL044946PP Hw : 1.4
Fw : 5.4(2)
Sw : 5.5(1)
5 48 WS-X6348-RJ-45 SAL04504779 Hw : 1.4
Fw : 5.4(2)
Sw : 5.5(1)
6 16 WS-X6416-GE-MT SAD04400CUY Hw : 1.1
Fw : 5.4(2)
Sw : 5.5(1)
7 16 WS-X6416-GE-MT SAL0537BGRZ Hw : 1.3
Fw : 5.4(2)
Sw : 5.5(1)
8 8 WS-X6408A-GBIC SAD0449070B Hw : 1.3
Fw : 5.4(2)
Sw : 5.5(1)
9 16 WS-X6416-GBIC SAL0607J10E Hw : 2.0
Fw : 5.4(2)
Sw : 5.5(1)
15 1 WS-F6K-MSFC2 SAD0504029B Hw : 1.2
Fw : 12.1(2)E,
Sw : 12.1(2)E,
16 1 WS-F6K-MSFC2 SAD05030NSM Hw : 1.2
Fw : 12.1(2)E,
Sw : 12.1(2)E,
DRAM FLASH NVRAM
Module Total Used Free Total Used Free Total Used Free
1 65408K 38722K 26686K 16384K 6925K 9459K 512K 288K 224K
Uptime is 212 days, 15 hours, 21 minutes
set boot system flash bootflash:cat6000-sup.5-5-1.bin
03-03-2004 05:22 AM
Check the website below. I think this is what you are looking for.
Hope this helps.
Steve
