RPS problems
skrowocsic
I have seen in an stacked switch a module wich an inusual RPS state:
info3750b1#sh env stack
SWITCH: 1
FAN is OK
TEMPERATURE is OK
Temperature Value: 34 Degree Celsius
Temperature State: GREEN
Yellow Threshold : 56 Degree Celsius
Red Threshold    : 66 Degree Celsius
POWER is OK
RPS is NOT AVAILABLE
SWITCH: 2
FAN is OK
TEMPERATURE is OK
Temperature Value: 33 Degree Celsius
POWER is OK
RPS is SUPPLYING
SWITCH: 3
FAN is OK
TEMPERATURE is OK
Temperature Value: 32 Degree Celsius
POWER is OK
SWITCH: 4
FAN is OK
TEMPERATURE is OK
POWER is OK
Is normal this situation?
Thanks, Juanan.
lgijssel
Level 9
Level 9
From what you posted, it looks as if only one switch is actually getting power from the IPS.
This is indeed weird. However, do not draw your conclusions too quickly.
First of all, you should verify that all switches have a connection to an RPS and that this RPS is actually powered itself.
regards,
Leo
