Serial-to-serial cable. Does it exist?
serj
I would like t interconnect two cisco routers for testing purposes, using their serial ports, but still can not find serial-to-serial cable (60-pins each side).
Should i make such cable by myself? And where can i get pinout for the cable like this?
Thanks!
2 Accepted Solutions
ankurbhasin
Level 9
Level 9
HI Seri,
You can connect 2 routers via back to back connection using srial ports. Need to have DTE to DCE connection.
Check this link
http://www.cisco.com/en/US/products/hw/routers/ps341/products_tech_note09186a00801a886f.shtml#dte_dce
http://pinouts.ru/data/cisco_v35_dce_pinout.shtml
Ankur
amit-singh
Level 8
Level 8
You have to use V.35 male-female cable.One side would V.35 male and the other would be v.35 female.
regards,
-amit singh
ankurbhasin
Level 9
Level 9
HI Seri,
Check this link
Ankur
amit-singh
Level 8
Level 8
regards,
-amit singh
Thanks!
I think, the problem is solved.
Once again - thanks to both of you!
