Setting up an interconnect between 2 - 6500s
JUSTIN LOUCKS
I was wondering what I need to do to properly configure the two GB interfaces on the sup. engines of a pair of 6500s to have them work properly as one pipe between the two. I am not real familiar with the proper syntax on CatOS and was hoping someone could give me some feedback on this.
Do I need to use the 'set port channel' and 'set trunk' commands? Anything else?
Any assistance would be appreciated.
Prashanth Krishnappa
You can channel for more bandwidth between the 2 switches. You will need to trunk if you have more than one VLAN which you need to pass on the links.
The following pages should help you with syntax
http://www.cisco.com/warp/public/793/lan_switching/6.html
http://www.cisco.com/warp/public/473/68.html
http://www.cisco.com/warp/public/473/70.html
