Setting up BGP
dave99999
Hello
I have 2 networks both of which are running ospf and they seem to be working fine. I am trying to use BGP to have both networks talk to each other.
I have been having some problems with that.
Do I need to set BGP on all my routers on each network? Or just the routers that are next to each other on the two networks?
Here are the commands I have used for the routers that are next to each other.
1st router
router bgp 400
network 172.24.0.0
neighbor 144.5.5.1 remote-as 500
2nd router
router bgp 500
network 144.5.0.0
neighbor 172.24.5.1
Am I missing commands?
---Dave
Harold Ritter
Level 12
Level 12
If this is a test setup, just redistribute BGP into OSPF in both AS and it should be fine. You don't need to redistribute OSPG in BGP since you are using a network statement to originate the routes in BGP.
Hope this helps,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
