08-24-2006 12:05 AM - edited 03-03-2019 04:40 AM
If I have 2 physical e1 links on my router, and want 2 1 mb lines on each, do I use 2 channel groups and timeslots 1-16 on each, can anyone help on this ?
08-24-2006 01:08 AM
Hi Carl
If you have subscribed to a channelized E1 then you can make use of channel-groups and time slots to have a single capacity of 1Mbps.
It all depends upon the E1 flavor which you have availed from the local TELCO.
regds
08-24-2006 02:26 AM
If I did this , could I use the other 1 meg link to connect to another site, would this mean I have 3 link, 2 remote and 1 for central ?
08-24-2006 04:33 AM
Hi Carl
In that case you can split the E1 between 2 locations and connect your central location with another E1.
regds
