03-18-2003 11:29 AM - edited 03-02-2019 05:58 AM
I'm filtering traffic on my edge router to relieve the load on my PIX. Should I bother? I started filtering out traffic to port 137-139 and to 445, since then people have complained of slower access to the internet.
My Edge Router is:
CPU utilization for five seconds: 20%/20%; one minute: 23%; five minutes: 29%
IOS (tm) C2600 Software (C2600-I-M), Version 12.1(2)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2000 by cisco Systems, Inc.
Compiled Tue 16-May-00 15:15 by ccai
Image text-base: 0x80008088, data-base: 0x80865F64
ROM: System Bootstrap, Version 12.1(3r)T2, RELEASE SOFTWARE (fc1)
uptime is 13 weeks, 6 days, 20 hours, 41 minutes
System image file is "flash:c2600-i-mz.121-2.T"
cisco 2621 (MPC860) processor (revision 0x600) with 44032K/5120K bytes of memory.
Processor board ID JAD05330C0L (3699876051)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
2 FastEthernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
My PIX is:
CPU utilization for 5 seconds = 1%; 1 minute: 0%; 5 minutes: 1%
Cisco PIX Firewall Version 6.2(2)
Cisco PIX Device Manager Version 2.0(1)
Compiled on Fri 07-Jun-02 17:49 by morlee
up 49 days 18 hours
Hardware: PIX-515, 32 MB RAM, CPU Pentium 200 MHz
Flash i28F640J5 @ 0x300, 16MB
BIOS Flash AT29C257 @ 0xfffd8000, 32KB
0: ethernet0: address is 0050.54fe.ef68, irq 10
1: ethernet1: address is 0050.54fe.ef69, irq 7
2: ethernet2: address is 0002.b3ad.7fda, irq 9
Licensed Features:
Failover: Disabled
VPN-DES: Enabled
VPN-3DES: Disabled
Maximum Interfaces: 3
Cut-through Proxy: Enabled
Guards: Enabled
URL-filtering: Enabled
Inside Hosts: Unlimited
Throughput: Unlimited
IKE peers: Unlimited
03-18-2003 03:20 PM
Your inbound filter on the router, forces, the router to use process switching for all packets inbound on that interface. This increases the load on the router. Your pix utilisation is normal, so you might want to shift the filtering to the pix, rather than on the router. PIX is a hardware based filtering system, so it would perform the filtering, much faster than the router can do, and also relieve the load on the router. This might help.
