show ip cache flow
Kashish_Patel
Level 2
Level 2
Can we find out if a flow is using tcp or udp using "sh ip cache flow" command? what do 06 and 11 indicate here?
Routert#sh ip cache flow
Te3/4            10.2.1.1    Vl52              1.1.1.1   06 8389 0017    48
Vl59             192.168.1.1    Te3/4            10.2.2.2    11 007B 007B     0
cadet alain
these are the hex values for the upper layer protocol :  so 6 in hex is 6 in dec and 11 in hex is 17 in dec
as you'll see here 6= tcp and 17= udp
http://www.iana.org/assignments/protocol-numbers/protocol-numbers.xml
Regards.
Alain
cadet alain
Regards.
Alain
Thanks Alain...Rated as 5.
