Shutdown more than 1 interface with a command
mcardell
Hi All,
What is the IOS command in the 4506 to shutdown or enable more that one port with a single command?
I do not want to go into each interface configuration and give "shutdown command" for each port!
Matteo
Prashanth Krishnappa
You can use the interface range command
Here is an example from my lab switch
Switch#sh mod
Mod Ports Card Type Model Serial No.
1 2 1000BaseX (GBIC) Supervisor(active) WS-X4515 JAB062408TV
4 48 10/100BaseTX (RJ45) WS-X4148 JAB031108W1
M MAC addresses Hw Fw Sw Status
1 000a.4173.f540 to 000a.4173.f541 0.4 12.1(12r)EW( 12.1(13)EW1, EAR Ok
4 0050.547b.0a30 to 0050.547b.0a5f 1.5 Ok
Switch#conf term
Enter configuration commands, one per line. End with CNTL/Z.
Switch(config)#interface range ?
FastEthernet FastEthernet IEEE 802.3
GigabitEthernet GigabitEthernet IEEE 802.3z
Port-channel Ethernet Channel of interfaces
Vlan Catalyst Vlans
macro macro keyword
Switch(config)#interface range fastethernet 4/1 - 48
Switch(config-if-range)#shut
Switch(config-if-range)#no shut
Switch(config-if-range)#end
Switch#wr
Building configuration...
Compressed configuration from 2090 bytes to 854 bytes[OK]
Switch#
