sniffer behind cisco switch possible?
aviation88
Hi there,
I kind of looking/wondering if it`s possible to have a port based VLAN cisco switch with a connection to a sniffer server?? If so, which cisco switch could handle it?
Personally I was thinking of the cisco 2948 G-L3 switch because of IP multicast possiblities but maybe someone can point me to another switch??
3 Accepted Solutions
scottmac
Level 10
Level 10
They will all do "SPAN," which will allow you to copy traffic from a port and send the copy out another port (say, to a "Sniffer" or other analyzer.
In some cases, you can send the copied traffic through the network to another switch and port (I believe this is only available on the 6500 series).
FWIW
Scott
SPAN - SWITCH PORT ANALYZER.
SPAN ports are used to capture the network traffic using sniffers like Cisco IDS,IPS that are connected to the SPAN port in the cisco switch.
swamy
5 Replies 5
scottmac
Level 10
Level 10
FWIW
Scott
Hi Scott,
I can`t find it on my switch manual. What does "SPAN" stands for?
swamy
"Switched Port Analyzer" -- it's a very good tool!
Read the following document for an excellent overview and more; Document ID: 10570.
Have a good one!
francis
