06-07-2004 09:32 AM - edited 03-02-2019 04:13 PM
When I do SPAN session on one of my switch, the destination port, where the PC capturing the data is plugged in, is locked out of the network, and I can no longer access the switch via a telnet session from any other PCs. I can still ping the switch and get into it via a console session but not via telnet.
Any clue why a SPAN session would do this?
As far as not being able to telnet, I am suspecting that my VTY lines are max out by a computer(s) that is/are either already connected to the switch or trying to connect, which leads to the following question:
Besides AAA, is there a way to find out who is telneting (or trying to telnet) into a switch or router from a PC (not from router or switch)?
I would really appreciate if could give me some pointers about why this is happening?
Thanks for the help
06-07-2004 10:55 AM
When you create a SPAN session the monitor port stops working as a normal port, all it can do it view traffic that is mirrored.
If you have a Cat OS based switch you can use the 'inpkts' option in the set span command, this allows the port to also function as a standard port.
I think the same feature is available in IOS based switches in version 12.1
Dave
06-07-2004 10:56 AM
oops! posted twice..
06-08-2004 08:03 AM
if you do a 'show users' you should see what IP's are logged into which session.
06-08-2004 09:06 AM
Thanks for the tip. I see the sessions being idle, and some of them point to computer that are no longer on the network. Is there a way to reset the idle connections without restarting the switch?
06-08-2004 09:06 AM
06-08-2004 01:50 PM
the command is 'clear line' and then whatever line you want to clear ie vty 1, vty 4 , etc.
