02-14-2005 11:07 AM - edited 03-02-2019 09:39 PM
Is there any command on a router to probe,that the speed over the interface is the same that our service provider are selling ?
02-14-2005 11:11 AM
I am pretty positive that you can't, your best bet is to use a test set (like a firebird) to determine the serial links speed. What type of circuit do you have?
02-14-2005 11:19 AM
Thanks...for you pretty positive.. We counted on interfaces Frame-Relay type that can be from 128 Kbps to 1984 Kbps and on each one of them discovering 2 PVC at least (DLCI)
