12-19-2005 12:27 PM - edited 03-03-2019 01:10 AM
I have a telco person wanting to put the management port of their phone switch on to the network in one of our remote offices. They say that it will not handle broadcast very well and it will cause it to reset.
So is there a way to limit the broadcast traffic to the port the phoneswitch is connected to. Or is there another way to accomplish this.
using switches like edge access switches 3500XL, 2900XL, 3550 etc and or small routers like 1700 series.
Thanks.
Solved! Go to Solution.
12-21-2005 03:17 PM
this is a per-interface configuration.
12-19-2005 12:48 PM
See the storm-control command reference. A 2.0 threashold will allow 2% of total bandwidth as broadcasts.
12-20-2005 10:18 AM
Thanks for the info. I'm assuming that storm-control is a global setting, is there a way to set something up for just one port?
12-21-2005 03:17 PM
