subneting problem (VLSM)
mansour alazzi
when i did subneting (VLSM) of may network id 192.168.1.0 first i make a subnetwork with CDIR /30 to connect two routers one R1 on 192.168.1.1 over interface G0/0 and the second R2 on 192.168.1.2 over interface G0/0 and then when i make another subnetowrk's ID 192.168.1.4 with CDIR /26 for my LAN and give the R1 192.168.1.5 over interface g0/1 but the 192.168.1.5 give me overlab with interface g0/0 on the same router
how it can be overlab the first NID is 192.168.1.0 and the second start at NID192.168.1.4  are  there any rules that i miss
or rules about how to arrange your subnetworks's IDs when you ues the VLSM
3 Accepted Solutions
Hi, @mansour alazzi
if you take 192.168.1.4/26 as subnet, its subnet IP range will be 192.168.1.0 - 192.168.1.63. so its overlaps with 192.168.1.0/30 which have range 192.168.1.0-192.168.1.3.
so suggestion is, to create big subnets from first IPs and build small subnets from remains in this kind of requirement.
Good luck
KB
@mansour alazzi
ip classless command.
But, If you take a lager network range after a smaller network range they will overlap
 Take the larger range First, then the smaller after that.
Joseph W. Doherty
". . . are there any rules that i miss . . ."
Yes, I suspect so.
Subnets address blocks all require starting on specific IP addresses.
A /30 must start on an IP address evenly divisible by 4.  A /26 must start on an IP address evenly divisible by 64.
Your /30 and /26, as specified, both start on the same .0, which is why they overlap.
As @Kasun Bandara and @Flavio Miranda explain, allocating subnets, back-to-back, in descending subnet sizes, if done correctly, will avoid accidentally overlapping subnets, but it's not required nor is often the best approach for long term IP subnet allocations
Hi, @mansour alazzi
Good luck
KB
@mansour alazzi
Joseph W. Doherty
Yes, I suspect so.
