05-27-2006 12:39 PM - edited 03-03-2019 03:24 AM
Does anybody know how to fix this, i get 1-3-6 ports on my switch AMBER, cisco(Trblsht) says replace firmware did this already... i am starting to think it might be my Mem anybody ever run into this problem??
1xNonfatal---Port loopback test.
3x Fatal---Content addressable memory test. Switch is not operational. Contact Cisco Systems.
6x Fatal---CAM SRAM test. Switch is not operational. Contact Cisco Systems.
Solved! Go to Solution.
05-28-2006 09:45 PM
Hi Friend,
I believe this is a hardware failure and you may need to contact Cisco TAC to get it replaced.
Have a look at different POST results
Ankur
05-28-2006 09:45 PM
Hi Friend,
Ankur
