Dear sir :
There are some problem when I config static arp table
in Switch3750 ? Following is description :
Section 1 : If static arp command already config on Switch3750 , then the PC connect to Switch3750 . PC's performance is very bad . Include Ping / FTP .
At this moment , MUST config " No arp ...." , then re-type static arp command " arp .... " , after that ,the problem will resolved .
Section 2 : Same as Section 1,static arp command already config on switch3750 ,and PC already connnect
to switch3750 . When PC disconnect the link almost 30 second then PC re-connect to switch3750. After that the PC's performance like Section 1 ,need to remove arp command the add again ,then the problem will resolved .
Section 3 : Same as Section 1 , Static arp command already config on switch3750 , nd PC already connnect
to switch3750 .When Switch Power off / power on , The PC's performance just like Section1 and Section2 .MUST remove static arp command the add again ...
and Switch 3750 IOS is 12.2.25SEA .
Does anyone could help me to resloved this problem ?
Thanks !!
Ted Wen.
