System was restarted by error - a SegV exception, PC 0x802000FC
seheng
HI There,
Is any one experience this error msg,
What does this mean,,,what is the Solution to fix this problem....
Below is the error msg:-
C2600 Software (C2600-JS-M), Version 12.0(8), RELEASE SOFTWARE (fc1)
Compiled Mon 29-Nov-99 15:26 by kpma (current version)
Image text-base: 0x80008088, data-base: 0x80B081E0
Stack trace from system failure:
FP: 0x813225A8, RA: 0x813225D8
FP: 0x813225B8, RA: 0x805EB97C
FP: 0x813225D8, RA: 0x805F3DE4
FP: 0x813225F8, RA: 0x806008A8
FP: 0x81322620, RA: 0x8060022C
FP: 0x81322640, RA: 0x806002DC
FP: 0x81322658, RA: 0x80208F60
Sim
sachinraja
Level 9
Level 9
Hi Sim,
Segv error happens due to the router accessing to an invalid memory address.
its better you open a case with cisco tac. You can refer to the following URL:
http://www.cisco.com/en/US/products/hw/routers/ps359/products_tech_note09186a0080189ddb.shtml
hope this helps... all the best..
Raj
