TA not accecpt incomming calls
furquan
I have installed TA (External Modem ISDN US-Robotics) for incomming calls on my Router 2621 on Wic2t (smart Serial).
The problem is that incomming could not connect, I have debug the modem and the results is as follows,,,
kiit#debug modem
Modem control/process activation debugging is on
kiit#
1d02h: TTY1: DSR came up
1d02h: tty1: Modem: IDLE->(unknown)
1d02h: TTY1: EXEC creation
1d02h: TTY1: create timer type 0, 14380 seconds
1d02h: TTY1: create timer type 1, 1800 seconds
1d02h: TTY1: DSR was dropped
1d02h: TTY1: Quickly dropping DTR
1d02h: tty1: Modem: READY->HASPROC
1d02h: TTY1: Line reset by "Exec"
1d02h: TTY1: Modem: HASPROC->HANGUP
1d02h: TTY1: destroy timer type 0 (OK)
1d02h: TTY1: destroy timer type 1 (OK)
1d02h: TTY1: destroy timer type 3
1d02h: TTY1: destroy timer type 4
1d02h: TTY1: destroy timer type 2
1d02h: TTY1: dropping DTR, hanging up
1d02h: tty1: Modem: HANGUP->IDLE
1d02h: TTY1: restoring DTR
kiit#
kiit#
Could any one tell what is the problem, Thanks in advance......
mljohnson
Level 4
Level 4
Hard to say; you should always have msec timestamps enabled, first of all:
service timestamp debug date msec
service timestamp log date msec
Next, the config would be useful to see; debug ppp negotiate would be good, too.
mark
I have the same problem (with EXEC only) with WIC-2A/S on 2611.
This problem is absent on DB-60 interfaceses (NM-4A/S).
any comments ?
