temperature status from 2960 switch using SNMP not working.
sossie
Hello
WS-C2960G-24TC-L   12.2(25)SEE3            C2960-LANBASE-M
I would like to get the temperature status from this 2960 switch (and several other models. Normally this OID should be:
.1.3.6.1.4.1.9.9.13.1.3.1.6
But it does not return anything.
The termperature status can be found from the command line by running:
"sh env temp"
This reports back ok, so I assume there is a temperate gauge in the switch.
This oid is part of the "CISCO-ENVMON-MIB" mib and accouding to the Cisco MIB selector it is supported on my switch and IOS - 12.2(25).
(Another thing I woudl like to monitor and should be supported is the fan status oid (.1.3.6.1.4.1.9.9.13.1.4.1.3). That doesn't return anything either.
What do I need to do to get the temperature environment status from SNMP query?
Cheers, Simon.
5 Replies 5
nkarthikeyan
Level 7
Level 7
Hi Simon,
have you enabled this command in the snmp configurations????
snmp-server enable traps envmon fan shutdown supply temperature status
Please do rate if the given information helps.
By
Karthik
Hi Karthik
Thanks for the response, good idea, I have enabled that but the snmp poll on that oid still fails.
I want to SNMP poll for the OID. I'm not too interested in receiving traps.
Cheers, Simon.
ngoldwat
Level 4
Level 4
Could you post the ouput of your SNMP walk?
Reference link.
Pavel Pokorny
It looks like C2960G (24 and 48 port version) has no info about temperature - I was searching very deeply, but nothing.
C2960G-8TC-L has info :
Temperature state : .1.3.6.1.4.1.9.9.13.1.3.1.6.1004
Temperature value : .1.3.6.1.4.1.9.9.13.1.3.1.3.1004
There is also no info about fan, only about power supply.
Sorry, info about FAN : .1.3.6.1.4.1.9.9.13.1.4.1.3.1004 (for 2960G).
