Token Ring to Ethernet Routing. Please help!
jhaggett
I need to connect a Token Ring segment to an Ethernet segment. I have a Cisco 2612, and I can't find any information on how to route the information across on one router. Do I have to configure DLSw to allow the NETBios information to traverse across to the Ethernet segment? Can anyone please send me in the right direction?
Thanks for your help!!
scottmac
Level 10
Level 10
The easiest / quickest thing might be to just configure it as a translational bridge.
Scott
Great.. Well, I couldn't get translational bridging to work, and I was told to just route it.
Robert Slusar
Are you able to ping from a device on the TR segment to something on the ethernet side? If you can, have you enabled NETBIOS over TCP/IP or are you trying to use native NETBIOS?
