Troubleshooting NAT Problem
sdross
I have a T1 line with my service provider. I have a 1602 router that was setup with dhcp and NAT. I could ping from my pc to my router (the LAN and WAN side), but I could not ping the ISP router from my PC.
After telnetting into the router I could ping my PC, I could ping the ISP and yahoo.com, everything, etc.
I disabled NAT and got a static address from my ISP and everything works fine. Is this a bug or is something not enable?
7 Replies 7
jcleary
Could you paste the configs
Here is the config to my router
Current configuration:
version 12.0
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname Router
logging buffered 4096 debugging
no logging console
enable secret 5 xxx
ip subnet-zero
ip name-server x.x.x.21
ip name-server x.x.x.22
ip dhcp excluded-address 192.168.1.1 192.168.1.10
ip dhcp pool local
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server x.x.x.21 x.x.x.22
domain-name xxx.net
lease 2
interface Loopback0
no ip address
no ip directed-broadcast
interface Ethernet0
ip nat inside
interface Serial0
no ip address
shutdown
service-module 56k clock source line
service-module 56k network-type dds
interface Serial1
ip address x.x.x.42 255.255.255.252
ip access-group 110 out
ip nat outside
service-module t1 data-coding inverted
service-module t1 timeslots 1-12
ip nat pool lan x.x.x.42 x.x.x.42 netmask 255.255.255.252
ip nat inside source list 1 pool lan overload
ip classless
ip route 0.0.0.0 0.0.0.0 Serial1
no ip http server
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 110 deny udp any any range netbios-ns netbios-ss
access-list 110 deny tcp any any range 137 139
access-list 110 deny udp any any eq bootpc
access-list 110 deny udp any any eq snmp
access-list 110 permit ip any any
line con 0
exec-timeout 30 0
password xxx
login
transport input none
line vty 0 4
exec-timeout 30 0
password xxx
login
end
For a single ip address you are using a pool. I think this is not needed. You could give
ip nat inside source list 1 interface serial 1 overload.
This should do the natting to all the private ip addresses with different port numbers.
-Deepu
Like, Deepu suggested, you dont need that pool configured. Just "ip nat inside source list 1 int s1 overload" should work.
Now give a show ip nat translation and see if translations are happening correct or not.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
ericlinji
I have the same problem with you. I can't ping outside but can FTP, telnet... I can't think out why. :D
Better change the IOS to another version.
Yes, I agree. You'd better change the NAT pool address or use interface address.
My problem is sloved. It's a bug ( I used ACL logging for NAT related ACLs).
BUG ID: CSCdt67507
IP NAT: issues with overload and cef/fast switching
Internet Control Message Protocol (ICMP) pings are not translated through Network Address Translation (NAT) in fast path if NAT Overload and ACL Logging are enabled.
Work Around: Don't use ACL logging for NAT related ACLs.
I will go ahead and try the suggestion stated above many times. My question though is what is the difference from using the overload with one address or using the Serial1 interface which has only one address? Same thing isn't it? I have probably 2 dozen plus T1s setup for clients this way and this is the first one that I have had trouble with. Also it is not just the pings that are not returning, I cannot surf, telnet, or anything as I think someone mentioned above.
Anyway, I will give it a try and let everyone know.
