Troubleshooting Serial interface
j.vashee
I have a wide area point to point connection via frame relay. The interface on my backbone router is UP/UP. My frame relay PVC is also active. The Serial interface at the router at the other end is also UP / UP. But the Sub interface is Down/ Down.
I have checked the IP addressess ; Encapsulation ; DLCI's and it seems to have been configured correctly
Anyone got any ideas what the problem could be.
Thanks in advance.
Jay
17 Replies 17
Just a thought -
Take out the sub interface se0.1 and re-create another sub-interface as se0/0.1 and do the usual no shutdown + add all the other information and se what happens.
Thanks -
Okay Folks the issue has been resolved. The Service provider messed the PVC definitions. Sorry to have troubled you.
Thanks for all your quick response.
01:16:17: Serial0(out): StEnq, myseq 202, yourseen 201, DTE up
01:16:17: datagramstart = 0x197FF94, datagramsize = 14
01:16:17: FR encap = 0x00010308
01:16:17: 00 75 95 01 01 00 03 02 CA C9
01:16:17:
01:16:17: Serial0(in): Status, myseq 202
01:16:17: RT IE 1, length 1, type 0
01:16:17: KA IE 3, length 2, yourseq 202, myseq 202
01:16:27: Serial0(out): StEnq, myseq 203, yourseen 202, DTE up
01:16:27: datagramstart = 0x197FF94, datagramsize = 14
01:16:27: FR encap = 0x00010308
01:16:27: 00 75 95 01 01 01 03 02 CB CA
01:16:27:
01:16:27: Serial0(in): Status, myseq 203
01:16:27: RT IE 1, length 1, type 1
01:16:27: KA IE 3, length 2, yourseq 203, myseq 203
01:16:37: Serial0(out): StEnq, myseq 204, yourseen 203, DTE up
01:16:37: datagramstart = 0x197FF94, datagramsize = 14
01:16:37: FR encap = 0x00010308
01:16:37: 00 75 95 01 01 01 03 02 CC CB
01:16:37:
01:16:37: Serial0(in): Status, myseq 204
01:16:37: RT IE 1, length 1, type 1
01:16:37: KA IE 3, length 2, yourseq 204, myseq 204
01:16:47: Serial0(out): StEnq, myseq 205, yourseen 204, DTE up
01:16:47: datagramstart = 0x197FF94, datagramsize = 14
01:16:47: FR encap = 0x00010308
01:16:47: 00 75 95 01 01 01 03 02 CD CC
01:16:47:
01:16:47: Serial0(in): Status, myseq 205
01:16:47: RT IE 1, length 1, type 1
01:16:47: KA IE 3, length 2, yourseq 205, myseq 205
01:16:57: Serial0(out): StEnq, myseq 206, yourseen 205, DTE up
01:16:57: datagramstart = 0x197FF94, datagramsize = 14
01:16:57: FR encap = 0x00010308
01:16:57: 00 75 95 01 01 01 03 02 CE CD
01:16:57:
01:16:57: Serial0(in): Status, myseq 206
01:16:57: RT IE 1, length 1, type 1
01:16:57: KA IE 3, length 2, yourseq 206, myseq 206
01:17:07: Serial0(out): StEnq, myseq 207, yourseen 206, DTE up
01:17:07: datagramstart = 0x197FF94, datagramsize = 14
01:17:07: FR encap = 0x00010308
01:17:07: 00 75 95 01 01 01 03 02 CF CE
01:17:07:
01:17:07: Serial0(in): Status, myseq 207
01:17:07: RT IE 1, length 1, type 1
01:17:07: KA IE 3, length 2, yourseq 207, myseq 207
01:17:17: Serial0(out): StEnq, myseq 208, yourseen 207, DTE up
01:17:17: datagramstart = 0x197FF94, datagramsize = 14
01:17:17: FR encap = 0x00010308
01:17:17: 00 75 95 01 01 00 03 02 D0 CF
01:17:17:
01:17:17: Serial0(in): Status, myseq 208
01:17:17: RT IE 1, length 1, type 0
01:17:17: KA IE 3, length 2, yourseq 208, myseq 208
01:17:27: Serial0(out): StEnq, myseq 209, yourseen 208, DTE up
01:17:27: datagramstart = 0x197FF94, datagramsize = 14
01:17:27: FR encap = 0x00010308
01:17:27: 00 75 95 01 01 01 03 02 D1 D0
01:17:27:
01:17:27: Serial0(in): Status, myseq 209
01:17:27: RT IE 1, length 1, type 1
01:17:27: KA IE 3, length 2, yourseq 209, myseq 209undebug all
01:17:37: Serial0(out): StEnq, myseq 210, yourseen 209, DTE up
01:17:37: datagramstart = 0x197FF94, datagramsize = 14
01:17:37: FR encap = 0x00010308
01:17:37: 00 75 95 01 01 01 03 02 D2 D1
01:17:37:
01:17:37: Serial0(in): Status, myseq 210
01:17:37: RT IE 1, length 1, type 1
01:17:37: KA IE 3, length 2, yourseq 210, myseq 210
