Showing results forĀ
Search instead forĀ
Did you mean:Ā
Trying to connect a Cable Modem to a wireless router In CPT
christ.9908
Hi, I want to say that I'm completely new to this!
I've been following The Getting Started with Cisco Packet Tracer course, and I'm currently trying to create a simple network.
My problem comes when I connected my cable modem/wireless router with a copper cross over cable. The two are connected but there's 2 red arrows that indicate that connection is not correctly made.
What should I do??
christ.9908
I tried with a copper straight-through cable and it's working. I've been able to complete the exercise with this cable but they're specifically asking for a copper cross over cable, why it's not working with that type of cable?
christ.9908
it might be version dependent. The file below was created in version 8.1.
Post your zipped project (.pkt) file...
