two adsl lines' problem?Can it be done?
litouch
My company has bought two adsl lines from a isp for accessing the Internet.I have a 1721 router and two wic-1adsl cards.Now I want to use these lines increasing the bandwidth,but I don't like to use policy-based routing by dividing the inside network.I hope the inside users can select a random route.
Can this be done?
I had a config but it didn't work well.
interface f 0
ip add x.x.x.x x.x.x.x
ip nat inside
interface atm 0
no ip add
interface atm 1
no ip add
interface dialer1
ip address nego
ip nat outside
ip mtu 1492
dial-group 1
dial-pool 1
encap ppp
ppp authen pap
ppp pap sent xxx pass xxx
interface dialer2
ip address nego
ip nat outside
ip mtu 1492
dialer-group 1
dialer-pool 2
encap ppp
ppp authen pap
ppp pap sent yyy pass yyy
ip route 0.0.0.0 0.0.0.0 dialer1
ip route 0.0.0.0 0.0.0.0 dialer2
ip nat inside source route-map adsl1 interface dialer1 overload
ip nat inside source route-map adsl2 interface dialer2 overload
route-map adsl1 permit 10
match ip address 1
match interface dialer1
route-map adsl2 permit 10
match ip address 1
match interface dialer2
access-list 1 permit any
dialer-list 1 protocol ip permit
Thanks a lot!
litouch
tepatel
PPP multilink support for ATM is available which you can find in the following document. See if this is possible in your scenario. But, I guess the provider also has to support it and configure for the same. http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a00801149cf.html
Just ignore the policy based routing config.
cteoh
Hi there, did you ended up getting this ML-PPP configuration to work?
I notice the ML-PPP was across ATM VCs and did not have CHAP authentication parameters that you would typically have for dial-up to a ADSL service provider.
