06-11-2021 02:23 AM - edited 06-11-2021 08:10 AM
As per the recommendation Hub router should be the DR and all spokes should be DROTHER by making OSPF priority of the tunnel interface in Spokes as 0.I am just trying to test the result when spoke is become DR and Hub is become BDR.
Anyone please help me to understand the concept behind following observations.
1. As per my understanding spoke 1 (DROTHER) should exchange OSPF routes with Hub (BDR) but in this case SPOKE1 can not access DR (Spoke2).But as per the above emulation when I check the routing table Hub route (BDR)r will not learn the Spoke1 (DROTHER) subnet .
2.When I clear OSPF process of Spoke 1 Hub router role perspective to the Spoke 1 change to DR from BDR.
But Hub is remain as BDR.
Please help me to clarify above confusions. Thank you very much for your valuable time....
06-11-2021 02:48 AM
Can you also post the configuration, if the Spokes set IP ospf pri 0, they will not elect DR or BDR
Make sure the OSPF network type - ip ospf network point-to-multipoint or broadcase on Hub
06-11-2021 08:04 AM - edited 06-11-2021 08:07 AM
06-11-2021 08:58 AM
My intention is to make Hub as BDR and Spoke as DR.
Why ? that is not the recommended design any of Live deployment i see.
HUB is the one where HQ sits, why you like all transit traffic go via spoke ? i do not understand what is your intention here ? Spoke to be DR ?
06-11-2021 09:43 AM
Hi Balaji,
My intention is to study behavior of the OSPF when Spoke is not DR. This is not a real world scenario.
manoj
06-11-2021 11:26 AM - edited 06-11-2021 11:26 AM
If the Lab, what is the exit Point of the network and routing point of view? if the Spoke become DR?
06-12-2021 07:56 AM
post the full configs (sh run) of all routers so we can lab this...
06-12-2021 07:45 PM
06-13-2021 10:53 AM - edited 06-13-2021 12:12 PM
Hello
I think It has nothing to do with dmvpn its just ospf design, clearing the process from the DR rtr wont make it then a BDR when the adjacency is reestablished, however if you reset the ospf process from the current BDR rtr then the DR election will change.
