Urgent help with 1700 series router
bzaayer299
Hi all,
I am a novice and I need some help. I have a 1700 router and I need to know what commands to give the router to point an external ip address to an internal ip address. We already have 3 external ip address pointing to 3 internal ip addresses. I need to point xxx.xxx.xxx.xxx to 192.168.1.252. I have no idea on how to do this and when I have finished inputting the commands into the router I do not know how to save the new configuration. Please help. My boss needs me to get this working! Please be as detailed as possible. I appreciate the help. You will be saving my butt.
Brina
5 Replies 5
m-carey
If you are looking to have a secondary IP address, in interface config mode, enter this command:
R(config-if)#ip address 10.1.2.1 255.255.255.0 secondary
R(config-if)#end
R#copy running-config startup-config
b.eman
Are you referring to a static nat translation? If you are you should see something like below in your config. Log into the router and type 'sh run' and look for something like the command below.
ip nat inside source static tcp 201.65.23.2 80 192.168.1.251 80 extendable
If you do not see that command type in 'show ip nat translation' and copy and past what you see here on the board.
Do you know what port you want to be able to access from the outside on this new machine? It is not a good idea to just open up any outside to any inside to this machine.
Let us know what you find out.
I'm sorry I was mistaken. The NAT is being done with our PIX box. How do I add the fowarding of 65.170.13.91 to 192.168.1.252 allowing only port 25 through? Below is my Pix config:
PIX Version 5.1(2)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxxx
passwd xxxxx
hostname const1pix
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 1720
fixup protocol rsh 514
fixup protocol smtp 25
fixup protocol sqlnet 1521
names
pager lines 24
logging on
no logging timestamp
no logging standby
no logging console
no logging monitor
no logging buffered
no logging trap
no logging history
logging facility 20
logging queue 512
interface ethernet0 auto
interface ethernet1 auto
mtu outside 1500
mtu inside 1500
ip address outside 65.x.x.x.255.255.248
ip address inside 192.168.1.1 255.255.255.0
arp timeout 14400
global (outside) 1 65.x.x.90
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) 65.170.13.91 192.168.1.254 netmask 255.255.255.255 0 0
static (inside,outside) 65.170.x.x.x.1.168 netmask 255.255.255.255 0 0
conduit permit icmp any any
conduit permit tcp host 65.170.13.91 eq smtp any
conduit permit tcp host 65.170.13.91 eq pop3 any
conduit permit tcp host 65.170.13.91 eq www any
conduit permit tcp host 65.170.13.92 eq 1494 any
conduit permit tcp host 65.170.13.91 eq ftp any
route outside 0.0.0.0 0.0.0.0 65.170.13.94 1
timeout xlate 3:00:00 conn 1:00:00 half-closed 0:10:00 udp 0:02:00
timeout rpc 0:10:00 h323 0:05:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
no snmp-server location
no snmp-server contact
snmp-server community grevnoc
no snmp-server enable traps
floodguard enable
isakmp identity hostname
telnet 192.168.1.0 255.255.255.0 inside
telnet timeout 5
terminal width 80
Cryptochecksum:xxxx
Brian
Enter the folloing
pix#config t
pix(config)#static (inside,outside) tcp 65.170.13.91 smtp 192.168.1.252 smtp netmask 255.255.255.255 0 0
pix(config)#exit
pix#copy running-config startup-config
That should do it.
Blake
What Blake told you is correct from a command standpoint, but it won't work for you b/c you already have this statement:
static (inside,outside) 65.170.x.x.x.1.254 netmask 255.255.255.255 0 0
conduit permit tcp host 65.x.x.91 eq smtp any
These statements say all allowed traffic for 65.170.13.91 goes to 192.168.1.254 (this is the static). As a result, the PIX can ONLY forward smtp hitting 65.170.13.91 to 192.168.1.254 (conduit)
You will either need to remove those statements or get another IP address. OR you could utilize one of your other static ips that is not already getting smtp traffic (i.e. 65.170.13.92). To do this you would do port redirection on the ip 65.170.13.92. To do this you would need to enter enable mode and then remove the static entry by doing:
logging into pix
type "en"
enter your enable password
You know you are in enable mode when you have a "#" in the line. Then:
conf t
no static (inside,outside) 65.x.x.x.168.1.168 netmask 255.255.255.255 0 0
write me
THEN
static (inside,outside) tcp 65.x.x.92 1494 192.168.1.168 1494
static (inside,outside) tcp 65.x.x.92 25 192.168.1.252 25
conduit permit tcp host 65.170.13.92 eq smtp any
write me
clear xlate
As a side note, you may also want to do the following in enable mode:
conf t
no fixup protocol smtp 25
write me
exit
When fixup is enabled, wierd things happen with e-mail.
