URGENT....How to Creat a Commoun VLAN
reagentom
Dear All;
I have Cisco Catalyst Switch 4006 with Supervisor II OS with 4232-L3 routing module, witch is configured for 5 VLANS, each VLAN cann't communicate with others.
I want to make VLAN 5 as a common VLAN so it can communicate with all others VLANS.
Attached is a copy of my show running-config on the routing blade
Please Help
28 Replies 28
Ahmed,
You host PC has the correct routes now. I have a doubt on your inter-vlan config now. I dont see any port-channel created in your config, whihc is essential in terms of inter-vlan routing on 4232-L3 blade...
Please set up the config as follows ( Already suggested by Ankur in his post ):
Create a port channel and trunk between sup and 4232 l3 blade.
Just read this lines
The WS-X4232-L3 module has 32 Fast Ethernet ports and two Gigabit Ethernet ports.
These two Gigabit Ethernet ports correspond to interfaces gigabit 1 and gigabit 2 in the router configuration. These Gigabit Ethernet ports are routed ports.
Internally, the module has two Gigabit Ethernet interfaces (gigabit 3 and gigabit 4) that connect the router to the switch backplane. The switch backplane uses the first two ports in that slot to connect to the router module. When you insert the WS-X4232-L3 module in slot 3, Gigabit Ethernet interfaces 3 and 4 connect to the backplane ports 3/1 and 3/2. Ports 3/1 and 3/2 are Layer 2 (L2) ports with configuration on the switch Supervisor Engine.
Gigabit Ethernet interfaces 3 and 4 are L3 ports with configuration on the router module.
Now you have to configure something like this on supervisor on module 3
#module 3 : 34-port Router Switch Card
set vlan 5 3/1-2
set trunk 3/1 nonegotiate dot1q 1-1005
set trunk 3/2 nonegotiate dot1q 1-1005
set port channel 3/1-2 mode on
Configure something like this on router 4232-L3 blade
interface GigabitEthernet3
no ip address
no ip directed-broadcast
no negotiation auto
channel-group 1
interface GigabitEthernet4
no ip address
no negotiation auto
channel-group 1
Now you can create subinterface for port channel for routing between vlans like this
interface Port-channel1.2
encapsulation dot1Q 2
ip address
ip helper-address
no ip redirects
interface Port-channel1.5
encapsulation dot1Q 5 native
ip address
ip helper-address
no ip redirects
This way intervlan routing will start between vlan 2 and vlan 5 and same way you will create port channel subinterface for other vlans and get it route first.
Once routing start working between all the valns we can go with ACl to restrict the traffic.
Lets take it one-by one.. first lets have the inter-vlan routing work fine and then we will take the other things.
Please refer the DOC as well listed in my first post.
regards,
-amit singh
Hi singh
I will try what u have suggest by tomorrow and let you know
But PLS I some question I need to understand it before start trying this steps
- if the inter-vlan routing is not working right now then how I can communicate between two PCs one in VLAN3 and the Other in VLAN 2 for Ex. If I have one computer in VLAN3 with IP 172.16.3.50 and gateway 172.16.3.1 (routing blade IP for Vlan3) and other computer in VLAN2 with IP 172.16.2.50 with gateway 172.16.2.1 (Routing blade IP for Vlan2) then these 2 computers are able to communicate perfectly!!!!
- The Problem only if I have GW for any PC as something else not as a routing blade IP Ex. One PC in VLAN2 with IP 172.16.2.50 and GW 172.16.2.10 (VLAN2 ISA server IP) and one PC in Vlan3 with IP 172.16.3.50 with GW 172.16.3.8 (VLAN3 ISA server IP) these 2 computers are not able to communicate !!
I need to understand how this is happening before we start to make any modification because the system is already running and I don’t want to face any trouble during the main time and the main problem is I’m new in the college and this system is designed by somebody else before and there is no any documentation it can help me to understand the Idea of the design.
So please if you want to see any configuration for review from switch or routing or from PIX I can post it for you, so u will be aware about everything in the system and be sure how we can solve this problem
Thanks singh and I’m so sorry for disturbing you so much by questions but I’m sure you can understand my point
THANKS
Well, if you are able to work fine with the inter-vlan routing as you discribed above then its not the issue with inter-vlan routing.
Now, just to be on the same page, rt now the problem is that you are able to communicate with hosts in diff-vlan except those which are in vlan 3 and 4 with ISA server as a gateway.
I did see the routes setup on your PC. Make sure that you are able to communicate fine among the hosts in other vlans like Vlan 2 to vlan 5, vlan 1 to vlan 5 etc.
What happens when you ping the Vlan IP ( IP on route blade for vlan 3)form the host in Vlan 3 ??? What happens when you ping the interface vlan IP of another vlan say Vlan 5 ????
Do a traceroute form the host in vlan 3 with the gateway as ISA server and should have a route to another vlan via its vlan interface IP. see where the hop is breaking.
It should work fine with the routes set up on hosts PC if your inter-vlan routing is working fine.
regards,
-amit singh
Hi singh,
I will get back to you tomorrow morning by the all required details but right now plas get the attached basic design for my network I have just design it in word format to give you more details about the current design how it's work and if u have any question pls let me know
Hi Ahmed,
I am little confused here after looking at your diagram. I am also in doubt that how come your inter-vlan routing is working without creating the port-channel between sup engine and the routing module, though I believe what you said about the inter-vlan communication among the hosts in different vlans.
But as pointed by Ankur and Me already that the way inter-vlan routing works on 4232-L3 blade is a little different.I still have a strong doubt that inter-vlan routing is not working correctly as desired.I think you are seeing a little different bahavior and I am surprised too.
In you diagram I dont see, any ISA server that we talked about which is used for internet. I see only PIX going to internet in Vlan 1 and that Vlan is used for internet.
I think we have to re-configure your inter-vlan routing on your switch.
Please see the link below :
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/inst_nts/78_10164.htm
Please see the attached config as desired. Once we are through with that then we will take it from there. Please plan a downtime in order to carry out this activity.Have your config backed up so that you can put it back in case if the new one doesnot work for you.
regards,
-amit singh
singh,
Thanks for that, because we have this confusion thats why I want to be sure first about the current setuation then we can start to apply the new modification,
about the ISA server I didn't put it in the digaram cuz it's normal PC connected to vlan (1 for Vlan3 with IP 172.16.3.8 amd GW 172.16.3.1 and 1 for vlan4 with IP 172.16.4.2 and GW 172.16.4.1)
about the configuration u have sent I think this command should be
set vlan 5 2/1-2
set trunk 2/1 nonegotiate dot1q 1-1005
set trunk 2/2 nonegotiate dot1q 1-1005
set port channel 2/1-2 mode on
becuse my routing blade in slot 2 nor 3 .. I'm right ??
I sent for u also some routing tests, please check and let me know if we can start by this way or we have to do somthing else first
Hi singh,
this is the all information u asked about but I did all this tests from PC in Vlan 3 before adding route and after adding the route so u can compare how its changing
Please if u need any clearification let me know
Thanks and waiting for ur advice
IPConfig
Connection-specific DNS Suffix . : mecit.com
Description . . . . . . . . . . . : Realtek RTL8139/810x Family Fast Eth
ernet NIC
Physical Address. . . . . . . . . : 00-01-2E-02-78-27
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IP Address. . . . . . . . . . . . : 172.16.3.101
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 172.16.3.8
DHCP Server . . . . . . . . . . . : 172.16.3.6
DNS Servers . . . . . . . . . . . : 172.16.3.6
212.72.1.186
1- Without Route
Active Routes:
Network Destination Netmask Gateway Interface Metric
0.0.0.0 0.0.0.0 172.16.3.8 172.16.3.101 20
127.0.0.0 255.0.0.0 127.0.0.1 127.0.0.1 1
172.16.3.0 255.255.255.0 172.16.3.101 172.16.3.101 20
172.16.3.101 255.255.255.255 127.0.0.1 127.0.0.1 20
172.16.255.255 255.255.255.255 172.16.3.101 172.16.3.101 20
224.0.0.0 240.0.0.0 172.16.3.101 172.16.3.101 20
255.255.255.255 255.255.255.255 172.16.3.101 172.16.3.101 1
Default Gateway: 172.16.3.8
Persistent Routes:
None
Ping 172.16.3.1 (Router IP for Vlan3)
OK
Ping 172.16.4.1 (Router IP for Vlan4)
Time Out
Ping 172.16.2.1 (Router IP for Vlan2)
Time Out
Ping 172.16.1.1 (Router IP for Vlan1)
Time Out
Ping 172.16.1.5 (Pix inside interface)
Time out
ping 172.16.3.8 (VLAN3 ISA Server)
OK
Ping 172.16.4.2 (Vlan4 ISA server)
Time Out
Ping any pc in Vlan 2 or Vlan 4 with GW as a VLAN routing blade
Time Out
Ping any pc in Vlan 3 or Vlan 4 with GW as a VLAN ISA server
Time out
C:\>tracert 172.16.4.3 (PC in VLAN 4 with GW as VLAN4 Routing blade)
Tracing route to 172.16.4.3 over a maximum of 30 hops
1 * * * Request timed out.
Trace complete.
C:\>tracert 172.16.4.20 (PC in VLAN 4 with GW as VLAN4 ISA Server)
Tracing route to 172.16.4.20 over a maximum of 30 hops
1 <1 ms <1 ms <1 ms 172.16.3.1
2 * * *
2- With route (after adding route for the pc)
route print
Persistent Routes:
Network Address Netmask Gateway Address Metric
172.16.4.0 255.255.255.0 172.16.3.1 1
172.16.2.0 255.255.255.0 172.16.3.1 1
OK
OK
OK
Time out
Time out
OK
OK
OK
Time out
C:\>tracert 172.16.4.3 (PC with GW as VLAN4 Routing blade)
2 <1 ms <1 ms <1 ms 172.16.4.3
Trace complete.
C:\>tracert 172.16.4.20 (PC with GW as VLAN4 ISA Server)
2 * * *
Ahmed,
2 * * *
This is not working because I believe that you have not added the reverse route on the PC in vlan 4 to reach other Vlans.
Please set it up and it wil work fine and then check all the inter-vlan routing part.
Do revert in case of any doubts
regards,
-amit singh
<--- sorry I don't understand what do u mean by that .. can u explain
sorry singh
Ahmed,
On your host PC in vlan 4 add the reverse route to reach another vlans as your gateway is ISA server i.e
c:\> route add 172.16.3.0 mask 255.255.255.0 172.16.4.1 -p ( i.e vlan 4 routing blade IP )
c:\> route add 172.16.2.0 mask 255.255.255.0 172.16.4.1 -p
c:\> route add 172.16.1.0 mask 255.255.255.0 172.16.4.1 -p
c:\> route add 172.16.5.0 mask 255.255.255.0 172.16.4.1 -p
This will work..
regards,
-amit singh
OK singh
I will try that and let u know
but this is not a solution for my case cuz I have to do the same for all PC's in each vlan :(
I just want to know if the inter-vlan routing is working or no right know ???
and if it's working how is it without port-channel config, if not then how there is a route between all sub interfaces for vlans !!!!
Ahmed,
Yes, you need to add reverse routes on all the PC's. That is mandatory or change the defulat gateway..
As per your posts and looking at the ping and trace output I would say inter-vlan routing is working but still pretty stange to me.. Need to check this on the Lab switch though..again very strange... This way I would say we have found out another way to configure inter-vlan routing on 4232-L3 blade... 3 cheers to you :-))
If you add the revrse routes on your PC and it waorks the way you want, then inter-vlan routing is working for sure.. Just try that.But as a best practice cisco will recommend to use the port-channel config as they might have tried diff things before releasing the DOC though...
HTH,
-amit singh
amit-singh
Level 8
Level 8
Ahmed,
In addition to my last post, I just want to make correction on point 1.. You can use l3 module in any slot except slot 1. So it can be in any slot from 2-6.
regards,
-amit singh
Thanks singh
yes I know cuz it's already in slot 2
Thanks for correction
