Using dialers with more than one physical interface
nathan.dixon
I have a router which dials a central site with 2 ISDN lines (4 B channels). If the highest interface (BRI 1/1) becomes disconnected/faulty the other wont connect at all.
When the two lines are plugged in and working OK I notice that the dialer starts with the highest BRI first and works its way down the interfaces. If the first one doesn't come up neither do any others. How can I make this happen so I at least get 128K in a possible fault scenario. If I admin down the bri1/1, 1/0 come up no probs. Its only when the line is at fault or the cable is unplugged I see this problem.
IOS 12.2(8)T4
Thanks.
Here's my config:
interface BRI1/0
no ip address
ip pim sparse-dense-mode
encapsulation ppp
dialer rotary-group 0
dialer-group 1
isdn switch-type basic-net3
no cdp enable
interface BRI1/1
no ip address
encapsulation ppp
dialer-group 1
no cdp enable
interface Dialer0
ip address x.x.x.x x.x.x.x
encapsulation ppp
load-interval 30
dialer in-band
dialer idle-timeout 300
dialer map ip x.x.x.x name xxxxx broadcast 123456
dialer load-threshold 1 either
dialer-group 1
no cdp enable
ppp authentication chap
ppp multilink
ppp timeout multilink link add 1
vkapoor5
Level 5
Level 5
See if you can use the 'dialer priority' and 'dialer rotor' commands given at http://www.cisco.com/univercd/cc/td/doc/product/software/ios121/121cgcr/dial_r/drdrd.htm
You can also try using dialer profiles instead if that is an option that you can consider.
