var/tmp permission issues in LMS2.2
nawas
Level 4
Level 4
I have been having problm running SWIM job, I have found this in the debug,
DriverUtil.pl 510 {3/25/2004 15:26:1}: /var/tmp/aaaEUaaYc could not be opened for reading
DriverUtil.pl 525 {3/25/2004 15:26:1}: Lock/Unlock operation did not succeed
for 10.5.0.54
I'm under the impression that I need to tweak my var/tmp permission, my current permissions as follows, can any help me in the right direction? Thanks,
drwxr-xr-x root sys 1024 Mar 30 14:33 var
drwxr-xr-x root other 1024 Mar 30 10:17 tmp
guffe
Hi There
I have put the stickybit on the /var/tmp simply to avoid any problem so i have drwxrwxrwt and i works
Ho that solv you problem
Yep. That is correct. /var/tmp needs to be wide open, 777. To add a litter safenet on it, you may set the sticky bit on it
chmod 777 /var/tmp
chmod +t /var/tmp
Thanks guys, that helped.
