Verizon Point-to-Point T1 on 1605 R
brian
Are there any tricks with these lines. I have everthing configured and the line will not come up. Verizon has claimed that the line is active but they do not see my equipment. I have plugged directly into their dmark to eliminate cable issues. The interface will not come out of inactive. I do mostly frame stuff.
13 Replies 13
deilert
Level 6
Level 6
Can you paste in your config frm both sides . Also you may want to find out who is providing clock
thisisshanky
Level 11
Level 11
On the 1605, what card do you have ? Is it one with a inbuilt CSU or do you have an external DSU.
Give a show frame-relay pvc on the router and find out what the status of the PVCs are. (assuming that u r running frame-relay - "I do mostly frame stuff")
When you test with Verizon, first try giving a hardloop at their demarc to see if the Smart jack is working properly. If the provider is able to see the loop, then there is nothing wrong with their circuit.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
I am using a T1 csu/dsu WIC on a 1605R. It is not frame which is probably why I am stuck. It is billed as a high speed DDS line. I have tried hdlc encapsulation but I have a feeling I am missing something in this area:
nterface Serial 0
no shutdown
description connected to FOXtoNA
service-module t1 clock source line
service-module t1 data-coding normal
service-module t1 remote-loopback full
service-module t1 framing esf
service-module t1 linecode b8zs
service-module t1 lbo none
service-module t1 remote-alarm-enable
ip address 172.16.6.9 255.255.255.252
encapsulation hdlc
what about the config from other side , also can you paste in sh int serial x & a sh ver from both sides.
One thing you may want to add is the serivce-module T1 fdl both command , this allows the LEC to loop your CSU .
I cannot get at the other side at the moment
sho ver
IOS (tm) 1600 Software (C1600-Y-M), Version 12.0(14), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2000 by cisco Systems, Inc.
Compiled Tue 31-Oct-00 16:18 by linda
Image text-base: 0x02005000, data-base: 0x0245EEAC
ROM: System Bootstrap, Version 12.0(3)T, RELEASE SOFTWARE (fc1)
ROM: 1600 Software (C1600-RBOOT-R), Version 12.0(3)T, RELEASE SOFTWARE (fc1)
NAtoFOX uptime is 1 minute
System restarted by power-on
System image file is "flash:c1600-y-mz.120-14"
cisco 1605 (68360) processor (revision C) with 6144K/2048K bytes of memory.
Processor board ID 23396694, with hardware revision 00000004
Bridging software.
X.25 software, Version 3.0.0.
2 Ethernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
WIC T1-DSU
System/IO memory with parity disabled
8192K bytes of DRAM onboard
System running from RAM
--More--
00:01:15: %QUICC_ETHER-1-LOSTCARR: Unit 0, lost carrier. Transceiver problem?sho int s0
Serial0 is down, line protocol is down
Hardware is QUICC Serial (with FT1 CSU/DSU WIC)
Description: connected to FOXtoNA
Internet address is 172.16.6.9/30
MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec, rely 255/255, load 1/255
Encapsulation HDLC, loopback not set, keepalive set (10 sec)
Last input never, output never, output hang never
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
8 input errors, 2 CRC, 3 frame, 0 overrun, 0 ignored, 3 abort
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 6 interface resets
0 carrier transitions
DCD=down DSR=up DTR=up RTS=up CTS=down
NAtoFOX#sho ver
NAtoFOX uptime is 6 minutes
Bridging software.
WIC T1-DSU
7K bytes of non-volatile configuration memory.
4096K bytes of processor board PCMCIA flash (Read/Write)
NAtoFOX#
Is this plugged in to the demac right now? If it is this is a carrier problem , you are not even receiving DCD , If not is there an extended demarc ?
If there is an extended demarc plug the router in to the demarc and see if your CD control lead is high or low , if low then it is a carrier problem
All the above control leads should be up
sorry, it is not plugged into the dmarc right now. I cannot get and internet connection and the dmark a the same time. I am working on that one. Router is on my desk. I wanted to be able to grab config info.
When you get some down time plug it in and do a sh int serial x, also if you can get the other side at this time it would be helpful
I am going to go to the remote put this back and go to the remote site now.
This is host side
NAtoFOX#sho int s0
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 output errors, 0 collisions, 8 interface resets
NAtoFOX#sho running-config
Building configuration...
Current configuration:
version 12.0
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname NAtoFOX
enable password xxxx
ip subnet-zero
no ip domain-lookup
interface Ethernet0
description connected to FastHub412
ip address 172.16.1.4 255.255.255.0
no ip directed-broadcast
interface Ethernet1
no ip address
shutdown
interface Serial0
no fair-queue
service-module t1 clock source internal
router rip
version 2
network 172.16.0.0
no auto-summary
ip classless
line con 0
transport input none
line vty 0 4
login
end
when I put the WIC into look back S0 comes right up. It has to be a telco probelm.
I will post results of lookback on remote shortly
Is the circuit a full T1 or fractional? You should have "service-module t1 timeslots 1-xx" depending on whether or not it is a full T1.
bcbv
This is a full T
