01-24-2005 10:00 PM - edited 03-02-2019 09:15 PM
i have 2 types of e1 cards 2MFT-E1 and NM-2CE1T1-PRI
so if i give
Line code hdb3
framing crc4
clock source line
it will work is it.
also
Clock source internal
Line code ami
if my telco supports both types of line code i can use any is it.
actually what's the meaning and difference between
clock source line and
clock source line primary
and clock source internal.
in my network there wont be any dial up users.
so for both types of cards if i opt
linecode hdb3
framing crc4
clock source line will it work.any prob in this configuration.
Thanks & regds
Binoy
01-24-2005 10:38 PM
I hope this link will clear your doubts:
Ankur
01-25-2005 12:22 AM
hi
pls send your views, it's very urgent
Binoy
01-25-2005 01:13 AM
it's very urgent pls
01-25-2005 01:19 AM
Binoy,
Normally you have to call your Telco and ask about the lineframing, clocksource, etc. The Telco will inform you about what to configure on your side, but you have to call them...
