view "debug" with Telnet connection
corey.mckinney
I have a router in a remote location so I can't use the console port. I have to connect via telnet. Is there a way that I can view debug messages as they are coming in, like I can with the console port?
mainesy
Yes, you can just type the following command at the enable prompt after enabling debugs:
Enable# terminal monitor
That will allow debug messages to be logged to your telnet session.
Josh
ankurbhasin
Level 9
Level 9
Hi Corey,
Just one command
"terminal monitor"
Check this link
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cr/hcf_r/cfn_12h.htm#wp1037494
Ankur
