Virtual Cisco devices
barrygallacher
Hi folks,
I'm a student in uni and trying to get my CCNA. I had a thought.
Since the Cisco Ios is linux based, would it be possible to take a standard IOS image, create a VMware machine with the relevant virtual hardware specs, and install ios to that device as a virtual device in order to have run and connect to other devices in things like GNS 3, or even connect directly (virtually) to VMware machines?
For instance if I had a Catalyst 2960 24 port switch. Could I take that IOS, create a virtual machine with 24 F/E network adapaters, copy the specs for ram, rom and CPU, and install the IOS image on there as a linux machine?
Many thanks
Barry
Seb Rupik
Hi there,
It depends on the underlying hardware architecture. IOS typically runs on MIPS. vMware et al can only virtualise x86 hardware.
Certainly ASA-OS, NX-OS and some IOS-XE can be virtualised in this manner, there are plenty of howtos online usually with mixed results.
You are better off using something like EVE-NG or maybe VIRL where some clever chaps have done the hard work for you.
cheers,
Seb.
Joseph W. Doherty
Seb is pointing you in the right direction, but, in theory, yes you could create an emulator for an IOS image running on a x86 platform. However, as Seb notes, the underlying hardware is different, so such an emulator would likely run very, very slowly.
