vlan between 3550-48-emi and 2924
yongjunh
I find some problems below:
1) in 3550 i configure 8 vlan 10.12.82.0/27 ,and a 4 port 802.1q trunk, computer plug in 3550 working correctly. in order to communicate with some computer plug in 2924 , i config the right trunk group corresponding with 3550 , but the computers between 3550 and 2924 can communicate with each other , Is really nessary to set the interface port in 2924 to specified vlan
2) I want set the management to another vlan expect vlan 1, but the management vlan in 2924 must be vlan 1, Can i do that.
thanks
xge
To answer your 1st question, the hosts in different VLANs can be communiated via routing.
Normally the hosts in same vlan can talk to each other.
As to the 2nd question, you can refer to the URL for management vlan setting:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat2900/cgcr29k/initconf.htm#xtocid1045012
