VMS 2.2 loading sensor config problem
milan.kulik
Level 10
Level 10
I've got IDS 4235 running software ver 4.1(4)S97 installed in my network.
Yesterday I installed VMS 2.2 basic (including CSCsa16682 and CSCee60913 patches).
I upgraded the IDS MC Server to the 4.1(4)S97 and added my IDS sensor successfully.
BUT when I try to change my sensor configuration using IDS MC, I'm in troubles:
1) Trying to configure filters I'm receiving "Problem with File /WEB-INF/screens/filters.jsp!!!Exception thrown by getter for property
destText of bean listentry" error message and no filters are shown.
2) When I modify one signature, the change is accepted. But trying to generate a config file I'm receiving an error:
"Generate failed. There are errors in the configuration of the Blocking Devices: (No destination addresses were provided.).
These errors must be corrected before you can deploy the configuration for Sensor.......
3) I don't see any configuration file in the configuration History.
Has anybody succeeded in adding a running IDS into a new VMS?
Milan
jsivulka
Level 5
Level 5
You seem to be facing the issue described in bug CSCee44396. You could also refer to CSCed87994. HTH
