08-14-2018 10:19 PM - edited 03-03-2019 08:52 AM
Hi friends
I want to deply WAAS_Express in 2901 router. according to cisco documents 2901 support the waas experss
but there no any licese for waas express.
so I buy the WAAS_Express license for 2901 and try to install that in the router, but the result shown that the license is not supported
what is the problem?
best regards.
08-15-2018 08:20 AM
Hello!
Can you provide your "show ver" output?
Best Regards,
08-15-2018 08:29 PM
there is no license for waas express even right to use.
best regards
08-15-2018 08:30 PM - edited 08-15-2018 09:13 PM
the command result for "show license detail WAAS_Express" is empty.
and when I add the router to the waas manager, the status of router is pending
and in configuration detail panel the ssl has the problem.
this problem is for waas express license?
the security license is enabled.
best regards
