WAN Connection PRI to PRI
gjimenez
Hello.
I need to create a PRI to PRI connection between two 375 routers. Each one has an NM-1CE1U.
Any help will be appreciated.
Kevin Dorrell
Level 10
Level 10
You cannot connect ISDN interfaces directly back-to-back - you will have to go through an ISDN switch.
Maybe you can configure the NM-1CE1U to do back-to-back plain E1, but I'm out of my depth there.
Kevin Dorrell
Luxembourg
