11-12-2002 09:14 AM - edited 03-02-2019 02:49 AM
Policy routing is configured on a 7200 router and applied to a Serial interface. There are three classes defined, one being a priority class.
What effect will configuring WRED (wth default settings) have on the priority class?
11-14-2002 10:32 AM
I think you are asking whether turning on WRED will impact priority (LLQ) class -- the answer is it depends! It depends on what type of configuration you are using on the serial interface. Are you using the modular QoS command line interface to apply the QoS policy? It is possible to use the MQC to run WRED on a particular traffic class and not touch priority (LLQ) class. If you apply WRED on the interface rather than using the MQC to create classes, you could impact LLQ type traffic.
Post an example of the config I can assist further.
11-14-2002 10:55 AM
MQC is being used, config below.
You are saying configuring RED within the class-map will and not the interface?
Thank you in advance.
class-map SP_to_SP
match access-group 112
class-map FTP
match access-group 111
class-map OSA_SNA
match access-group 110
policy-map DS3
class FTP
bandwidth 5000
class SP_to_SP
bandwidth 5000
class OSA_SNA
priority 5000
class class-default
fair-queue
int s1/0
service-policy output DS3
11-14-2002 03:14 PM
I am saying to enable it within the policy map for the particular class that you want to WRED. For example, if we want to do WRED on the class FTP only, just insert random-detect as shown below in your config. This assumes that you want to use the default settings for WRED. This configuration will have no impact on the traffic class that you have placed in LLQ (priority). Don't do WRED on the interface. I hope this helps!
policy-map DS3
class FTP
bandwidth 5000
random-detect <--- insert this command to WRED FTP
class SP_to_SP
bandwidth 5000
class OSA_SNA
priority 5000
class class-default
fair-queue
11-14-2002 10:57 AM
I meant to ask:
You are saying configuring RED within the class-map will and not the interface will not affect the LLQ class?
