10-22-2003 08:27 AM - edited 03-02-2019 11:11 AM
I need to make a simple PBR but it just don't seem to work. Let me brief you... I have router with a default route to another router connected to the internet, however i want that one host (192.168.127.2) jump to other router (think it like a rudimentary load-balance). But it just dont work... this is part of the conf:
interface FastEthernet8/0/0
+++ EXIT INTERFACE +++
ip address 10.0.100.1 255.255.255.0
full-duplex
no ipv6 mfib fast
mls rp vtp-domain xxxx
mls rp vlan-id 7
mls rp management-interface
mls rp ip
interface FastEthernet8/1/0
no ip address
full-duplex
no ipv6 mfib fast
interface FastEthernet8/1/0.110
+++ IN INTERFACE +++
encapsulation isl 110
ip address 192.168.127.1 255.255.255.0
ip policy route-map test
no ip redirects
ipv6 address xxxxxxxxx
ipv6 enable
ipv6 nat
access-list 1 permit 192.168.127.2 log
route-map test permit 10
match ip address 1
set ip default next-hop 10.0.100.2
I even remove the defaul route just to see what'd happend with no positive results.... I highly appreciate your help
10-22-2003 07:15 PM
Can you replace the "set ip default next-hop 10.0.100.2 " with "set ip next-hop 10.0.100.2 " and check it.
10-23-2003 06:05 AM
Actually I got to find information about this. It turns out that when CEF or dCEF is enable it just rule out PBR, in the moment I enter "no ip cef" PBR start working. I currently have IOS 12.3T2 ENTERPRISE for the 7513. Does any one know what IOS can I use to succesfully run PBR and CEF???
TIA
10-23-2003 05:32 PM
Sounds like a bug, as I believe PBR has been CEF-capable for a good while now. Have you contacted TAC about this?
10-24-2003 05:39 AM
You are righ baranski it is a bug. Check bug # CSCdy06253. But it is supposed to be fixed however i recently upgrade to IOS 12.3(2)T2 in my 7513 and still. This is giving me a lot of headache because there are some features that require CEF (NBAR and such) but i also need PBR. Any more feedback on this issue will be thank.
10-24-2003 04:02 PM
Is there a reason why you're using a bleeding-edge IOS version? Generally the newest T train releases are best avoided unless there are specific features that you need that can only be found in those versions.
So the best solution may be downgrading to a version that's known to be more stable. TAC may be able to give advice on which version to go to.
10-24-2003 11:32 AM
Change your set command to the itnerface you want it to go out.
set interface fa8/0/0
Or just set it next hop
set ip next-hop x.x.x.x
