08-22-2003 08:52 AM - edited 03-02-2019 09:49 AM
On a 7206 router I am seeing hundreds of flows with protocol 11. Any idea what application uses this protocol? Here is a small portion of the output of 'sh ip-cache flow':
Protocol Total Flows Packets Bytes Packets Active(Sec) Idle(Sec)
-------- Flows /Sec /Flow /Pkt /Sec /Flow /Flow
TCP-Telnet 621 0.0 26 65 0.0 10.0 15.3
TCP-FTP 4 0.0 21 50 0.0 2.4 1.4
TCP-FTPD 16 0.0 9 40 0.0 0.3 1.5
TCP-WWW 430 0.0 6 128 0.0 0.3 2.9
TCP-other 15646 0.0 22 284 0.0 2.0 6.7
UDP-DNS 783 0.0 1 71 0.0 0.0 15.4
UDP-NTP 27 0.0 1 88 0.0 0.0 15.4
UDP-Frag 209 0.0 3 176 0.0 3.1 15.5
UDP-other 5389 0.0 16 474 0.0 0.3 15.5
ICMP 749 0.0 2 202 0.0 0.6 15.5
IP-other 8 0.0 23 46 0.0 21.6 15.5
Total: 23882 0.0 19 312 0.1 1.7 9.5
SrcIf SrcIPaddress DstIf DstIPaddress Pr SrcP DstP Pkts
Fa6/0 164.72.153.194 Fa6/0 164.72.155.157 11 0000 0000 14
Fa6/0 164.72.153.33 Fa6/0 164.72.155.153 11 0000 0000 1
Fa6/0 164.72.154.85 Fa6/0 164.72.155.157 11 0000 0000 1
Fa6/0 164.72.155.157 Fa6/0 164.72.153.186 11 0000 0000 1
Fa6/0 164.72.153.186 Fa6/0 164.72.155.157 11 0000 0000 1
Fa6/0 164.72.155.159 Fa6/0 164.72.152.160 11 0B97 0B97 2
Fa6/0 164.72.152.238 Fa6/0 164.72.155.159 11 0B97 0B97 2
Fa6/0 164.72.152.247 Fa6/0 164.72.155.159 11 0B97 0B97 2
Fa6/0 164.72.152.192 Fa6/0 164.72.155.159 11 0B97 0B97 2
Fa6/0 164.72.155.153 Fa6/0 164.72.153.33 11 0000 0000 1
Fa6/0 164.72.155.159 Fa6/0 164.72.152.247 11 0B97 0B97 2
Fa6/0 164.72.155.159 Fa6/0 164.72.152.238 11 0B97 0B97 2
Fa6/0 164.72.154.105 Null 164.72.154.127 11 008A 008A 1
Fa6/0 164.72.154.66 Null 164.72.154.127 11 008A 008A 1
Fa6/0 164.72.152.160 Fa6/0 164.72.155.159 11 0B97 0B97 2
Fa6/0 164.72.155.159 Fa6/0 164.72.152.176 11 0B97 0B97 2
Fa6/0 164.72.152.176 Fa6/0 164.72.155.159 11 0B97 0B97 2
08-22-2003 09:40 AM
This could be it...
http://honeynet.hackers.nl/reverse/results/sol/sol-06/advisory.html
08-22-2003 09:48 AM
Thanks for the information.
I actually may be OK. I was reading the protocol field in the flow output as a decimal number instead of a hex number. If that field is a hex number then hex 11 = dec 17 which is UDP and completely valid.
I know that the source port and destination port fields are hex. Is that true for the source and destination protocol fields also?
