Which hardware to use with Frame Relay
h.parsons
Level 3
Level 3
I am looking for the best way to connect a remote site using frame relay. I am having trouble choosing the hardware. At one site I have a Cat 6509 and the other site has nothing. I need some suggestions on the hardware I need.
hbejinha
hi,
With 2 routers 2600 in each site.
Could be the best to you
could be this shematic
3500-2600---___---2600-6509
Hugo Bejinha
I see that you have a 6509 at one end, which I assume is your HO. If you plan to add more sites, you might want to go to a high end router such as 3700 or even 7200, depending upon how many more sites you are adding. If its just one site your remote site router neednt be a 2600, you can even use a 1700 router.
Ofcourse you will also need a switch at your remote office, like a 2950 or 3550.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
h.parsons
Level 3
Level 3
If I use the 1751 router with the integrated 4 port switch will I still need the switch at the remote site.
Hi!
that's enough for present use. If you are upgrading your system , you should go for other switch.
HTH.
Rgds
Vimal
