07-06-2004 01:24 PM - edited 03-02-2019 04:52 PM
Hi, We have a card like the one described above (WS-X6548V-GE-TX)10/100/1000BaseT GE. We need to install it in a Catalyst 6509.
This is what we have:
WS-C6509 Software, Version NmpSW: 7.4(3)
Copyright (c) 1995-2002 by Cisco Systems
NMP S/W compiled on Nov 27 2002, 16:27:21
System Bootstrap Version: 5.3(1)
Hardware Version: 2.0 Model: WS-C6509 Serial #: SCA040201D6
This card is not recognize by this switch.
There is a way to install this card on my switch and make it works?
What can I do ?
Thanks a lot for your help
Regards!
07-06-2004 04:36 PM
The Software Advisor utility on CCO comes up with 12.2(19)E1 as the minimum release.
07-10-2004 03:09 AM
The WS-X6548V requires CatOS 7.6(1) or above.
See Table 1 Product and Software Version Matrix (http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/relnotes/ol_1982.htm#wp20834) in the release notes
07-10-2004 11:06 AM
And if this is a Sup1a, note that 128Mb DRAM on the Supervisor engine is recommended to run 7.6(x)
