x25 windowsize-problem ?!?
rabeder
hi,
sometimes i have problems wit a x25 connection.
a x25 workstation has sometimes problem when it tries to connect.
i did a "debug x25" and saw following problem:
Feb 25 08:51:09.882: Serial0/1: X.25 I D1 RR (3) 8 lci 1 PR 1
Feb 25 08:51:09.886: [10.22.208.2,11597/192.168.128.2,1998]: XOT I D1 RR (3) 8 l
ci 1 PR 2
Feb 25 08:51:09.886: Serial0/0: X.25 O D1 RR (3) 8 lci 1 PR 2
Feb 25 08:51:09.886: Serial0/1: X.25 I D1 RR (3) 8 lci 1 PR 2
Feb 25 08:51:09.890: Serial0/1: X.25 O D1 Data (15) 8 lci 1 PS 2 PR 5
Feb 25 08:51:09.890: Serial0/1: X.25 O D1 Data (15) 8 lci 1 PS 3 PR 5
Feb 25 08:51:09.890: Serial0/0: X.25 I D1 Data (15) 8 lci 1 PS 2 PR 5
Feb 25 08:51:09.894: [10.22.208.2,11597/192.168.128.2,1998]: XOT O D1 Data (15)
8 lci 1 PS 2 PR 5
Feb 25 08:51:09.894: Serial0/0: X.25 I D1 Data (15) 8 lci 1 PS 3 PR 5
8 lci 1 PS 3 PR 5
Feb 25 08:51:09.910: [10.22.208.2,11597/192.168.128.2,1998]: XOT I D1 Data (28)
8 lci 1 PS 5 PR 2
Feb 25 08:51:09.910: Serial0/0: X.25 O D1 Data (28) 8 lci 1 PS 5 PR 2
Feb 25 08:51:09.910: Serial0/1: X.25 I D1 Data (28) 8 lci 1 PS 5 PR 2
Feb 25 08:51:09.954: [10.22.208.2,11597/192.168.128.2,1998]: XOT I D1 Data (28)
8 lci 1 PS 6 PR 2
Feb 25 08:51:09.954: Serial0/0: X.25 O D1 Data (28) 8 lci 1 PS 6 PR 2
Feb 25 08:51:09.958: Serial0/1: X.25 I D1 Data (28) 8 lci 1 PS 6 PR 2
Feb 25 08:51:09.958: [10.22.208.2,11597/192.168.128.2,1998]: XOT I D1 RR (3) 8 l
ci 1 PR 3
Feb 25 08:51:09.958: Serial0/0: X.25 O D1 RR (3) 8 lci 1 PR 3
Feb 25 08:51:09.962: Serial0/1: X.25 I D1 RR (3) 8 lci 1 PR 3
Feb 25 08:51:09.962: [10.22.208.2,11597/192.168.128.2,1998]: XOT I D1 RR (3) 8 l
ci 1 PR 4
Feb 25 08:51:09.962: Serial0/0: X.25 O D1 RR (3) 8 lci 1 PR 4
Feb 25 08:51:09.966: Serial0/1: X.25 I D1 RR (3) 8 lci 1 PR 4
Feb 25 08:51:09.966: [10.22.208.2,11597/192.168.128.2,1998]: XOT I D1 Data (28)
8 lci 1 PS 7 PR 4
Feb 25 08:51:09.966: Serial0/0: X.25 O D1 Data (28) 8 lci 1 PS 7 PR 4
Feb 25 08:51:09.970: Serial0/1: X.25 I D1 Data (28) 8 lci 1 PS 7 PR 4
Feb 25 08:51:09.970: X.25 Data packet, Bad P(S), Receive window violation
Feb 25 08:51:09.970: Serial0/1: X.25 O D1 Reset (5) 8 lci 1
Feb 25 08:51:09.970: Cause 0, Diag 1 (DTE originated/Invalid P(S))
Feb 25 08:51:09.974: Serial0/0: X.25 I D1 Reset (5) 8 lci 1
Feb 25 08:51:09.974: Cause 0, Diag 1 (DTE originated/Invalid P(S))
Feb 25 08:51:09.974: Serial0/0: X.25 O D2 Reset Confirm (3) 8 lci 1
Feb 25 08:51:09.974: [10.22.208.2,11597/192.168.128.2,1998]: XOT O D1 Reset (5)
8 lci 1
Feb 25 08:51:09.974: Serial0/1: X.25 I D2 Reset Confirm (3) 8 lci 1
Feb 25 08:51:09.978: Serial0/1: X.25 O R1 Clear (5) 8 lci 1
Feb 25 08:51:09.978: Cause 0, Diag 114 (DTE originated/International protocol
problem)
Feb 25 08:51:09.978: Serial0/0: X.25 I R1 Clear (5) 8 lci 1
problem)
Feb 25 08:51:09.978: [10.22.208.2,11597/192.168.128.2,1998]: XOT O P4 Clear (5)
8 lci 1
Feb 25 08:51:09.982: Cause 0, Diag 114 (DTE originated/International protocol
problem)
Feb 25 08:51:09.982: [10.22.208.2,11597/192.168.128.2,1998]: XOT I P6 Data (28)
8 lci 1 PS 0 PR 4
Feb 25 08:51:10.034: [10.22.208.2,11597/192.168.128.2,1998]: XOT I P6 Reset Conf
irm (3) 8 lci 1
Feb 25 08:51:10.042: [10.22.208.2,11597/192.168.128.2,1998]: XOT I P6 Clear Conf
irm (3) 8 lci 1
Feb 25 08:51:10.042: Serial0/0: X.25 O R1 Clear Confirm (3) 8 lci 1
Feb 25 08:51:10.042: Serial0/1: X.25 I R1 Clear Confirm (3) 8 lci 1
Feb 25 09:59:04.236: %SYS-5-CONFIG_I: Configured from console by lrzsrab on vty0
(10.18.20.200)
XOT-GW2#
XOT-GW2#
XOT-GW2#
XOT-GW2#
XOT-GW2#
i do not really understand the message "Receive window violation" becaus my router receives PS=7 and we have modulo8, so 7 is allowed - right ???
So why has my router a problem with a packet P(S) = 7 ??
modulo 8 means from 0 to 7 right ??
thanks for any help !!
andreas.richter
First of all modulo has nothing to do with window size. It seems your x.25 workstation has configured a higher layer 3 window size than your router. Cisco uses a default window size of 2. As you can see your x25 workstation sends more than two packet without waiting for an acknoledgement. Check the window-size of your workstation and then adjust the ws on your router. Important: you have to configure it incoming and outgoing:
x25 win
x25 wout
Don't try to play with figures, configure the exact values.
Andreas
hi,
thanks for answer.
win=7 (out and in) means 8 pakets could be without ack - right.
i always thought modulo is the maximum numer of unacknowledged pakets ??!!!?? - anyway:
the routers have a windowsize of 7 (in/out):
the config of the router:
interface Serial0/2
description Verbdg. ins DATUS_X25 (f. X25 Kunden, Bankomaten,...)
bandwidth 1024
ip address 1.1.1.1 255.255.255.252
encapsulation x25
load-interval 30
x25 htc 400
x25 win 7
x25 wout 7
x25 accept-reverse
so winsize is configured to 7 - the admin of the workstation said that he has also a layer 3 windowsize of 7 - that´s my problem.
ps:
i receive this x25 data over a xot-cloud as you can see in the trace - could this be the problem ?
i also checked the router at the other side of the xot-cloud - it also has win=7 in/out.
any ídea ?
Which Interface is your workstation connected to? Seriell 0/0 or seriell 0/1?
Ask the admin which win-size is 7, layer 2 (HDLC) or layer 3 (x.25). You have to be sure that layer 3 win-size is 7. Please post a longer debug, but it seems one win size is only 4.
Andreas
